Cracked Engine Case Mount Area..
发表于 2021-8-31 23:36:36 | 显示全部楼层 |阅读模式
Had a engine case on the bench this A.M. with instructions to repair the case crack where the engine mounts to the chassis...Found it was busted inside also..Pics are in order..#1..Case..#2..3..and 4 cracks in mount and inside..Last set pics next post..200 amps?3/32 Red End..1/16 5356 FillerEngine is back and running by 2 PM...I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Last set..#5 And 6 Ground out crack..#7 Inside weld..Could not get the grinder in there to dress it before welding so we just go for it..#8 and 9 is the finished job...That's about it!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Doesn't look like that casting was too oily or greasy, Zap.  Somebody must have done you a good turn and cleaned it really well before delivering it to you for repair.  Either that or you skipped the dirty work photos...Looks like a good casting too.  I didn't see any pores in the areas you ground down(with a carbide burr, I'm guessing?)  That must have made it less of a hassle to repair.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Actually it looked quite new..The mount was cracked when the owner ran into something with it.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks good to go. I see the black stuff that floated to top of puddle, castings are a pain. Did you have to hold puddle to float the crap out, or was it good enough to just run it? PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:Originally Posted by castweldLooks good to go. I see the black stuff that floated to top of puddle, castings are a pain. Did you have to hold puddle to float the crap out, or was it good enough to just run it? Peter
GMT+8, 2025-12-26 00:50 , Processed in 0.077209 second(s), 18 queries .
