This is a project I started to help me learn to weld. The welds were with a Lincoln Pro 180 Mig welder with C35 gas. Really enjoyed making this stand. The dimensions are 4' X 5'. The stand is eight feet tall. The frame is 1" square tubing 14 ga. 3/4 plywood for the floor and Smartsiding for the sides.I still have the blue covering over the plexiglass. Attached Images
Reply:THAT IS NOT HUNTING !! that siting in a BOX with a gun weighing go out and earn the kill. or are you in to photography?Last edited by T E B; 06-20-2011 at 02:59 AM.
Reply:Looks got . I do think you need a few cross braces for your legs to stiffen it up.
Reply:Originally Posted by FarmerLooks got . I do think you need a few cross braces for your legs to stiffen it up.
Reply:Originally Posted by T E BTHAT IS NOT HUNTING !! that siting in a BOX with a gun weighing go out and earn the kill. or are you in to photography?
Reply:Very nice to get out of the wind when its well below 0*F and the wind is blowing 30+mph. Still takes skill to find the right spot and keep your scent down walking in. Now hunting corn fields is entirely different, might as well sit on the road in the truck and listen to the radio if your hunting corn fields
Reply:Or be the ultimate in laziness and do what I do... trap hogs. I don't care for hunting, and I like the taste of pork better than venison.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:I'd be interested to see how the legs tie into the frame... Looks like a heavy breeze away from an accident (maybe not after seeing those stakes)ESAB Heliarc 252
Reply:Originally Posted by AndyAOr be the ultimate in laziness and do what I do... trap hogs. I don't care for hunting, and I like the taste of pork better than venison.
Reply:I suppose a smart deer would sneak around back and knock down the stepladder.Tim
Reply:Based upon the pics, I assume that you can truck this in to the hunting location then set it up, or does it come apart so you can haul it in a piece at a time on an ATV or whatever?Qualified & experienced at welding scrap metal
Reply:The legs slip out to allow you to move it easier. I am going to put cross braces to improve stability. Going to use angle iron material for the braces.
Reply:Originally Posted by arkie7671The legs slip out to allow you to move it easier. I am going to put cross braces to improve stability. Going to use angle iron material for the braces.
Reply:It is a great start. We are on our way to being farmers! Our site is always under construction so check back often for updates. http://www.philosophyfarmstyle.com/ |
