ESAB Migmaster 251 Replacement GUN???
发表于 2021-8-31 23:36:33 | 显示全部楼层 |阅读模式
Guys I am rebuilding an Old ESAB MigMaster 251. I need a New MIG Gun with Euro Quick Connection. Any ESAB owners out there replaced the Old MT-200 Mig Gun and are happy with the New Gun? What Gun are you using?
Reply:I haven't replaced mine yet on my gun.  But I am looking for a longer one.  HTP sells some nice ones.  Profax offers some really nice, moderate priced ones.  What's wrong with your MT200?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:My Migmaster 250, came with the new Gunmaster 250 gun that replaced the MT-200. Its a fairly good gun. For most of my usage though I don't need the 15 ft cable length. So most of the time, I actually run a 10 ft Binzel Alpha 2. This has been a real nice gun. Attached Images
Reply:A little light duty for my tastes.But I could use it  on some light duty areas.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:A Binzel alpha 2 is more then enough gun for a Esab 251. If you have any issues, the 350 amp swan-neck screws right on. (with jump liner) If you go to a 350 amp gun, the cable gets way too stiff and bulky. The Binzel #2 takes # 11 tweco tips although the Binzel style setup is heavier-duty.
Reply:The Alpha 2 has a 60% duty cycle rating @ 200 amps with a mixed gas, which makes it a fairly robust gun for my home hobbyist usage. I mostly weld 1/4" and thinner, so 200 amps is generally about all the higher I really need to take the output of the machine up to.
Reply:Gents Due to personnell issues I just picked up the Binzel Alpha 2, 15ft, .035 to .045 wire mig gun off of Ebay. It is a kit I have to cut the GUn and cable liner to length, but everything looks good. I will be building Propane tank BBQ pits (1/4 inch thick) and Double wall insulated BBQ pits out of 2 X 2 square tubing and thin sheet metal. Thin metal on the walls and 1/4 inch in the bottom, Fire box and Coal chute. Most of the stuff will be salvaged Metal to keep cost down. Lots of rust to flap wire off. What wire would you recommend for a beginner with the above job??
GMT+8, 2025-12-26 00:51 , Processed in 0.094223 second(s), 18 queries .
