helmet
发表于 2021-8-31 23:36:30 | 显示全部楼层 |阅读模式
ok so im trying to figure out how i can stop the inside lens of my lincoln auto darkening hood from getting moisture and fogging up while im welding! any suggestions?
Reply:1)wear a respirator mask2) weld in a heated room3)use  anti fog spray for motorcycle helmets.--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:4) stop breathing... .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Try to direct you breath down and away from your screen...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by Donoharm1)wear a respirator mask....
Reply:heat your lens with a hair dryer.
Reply:http://rolfje.wordpress.com/2010/04/...met-visor-tip/Works for the inside cover shield.
Reply:wonder what fog-x would do?tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by DSW4) stop breathing...
Reply:Originally Posted by BistineauCheapest solution so far.
Reply:Originally Posted by brucerwonder what fog-x would do?
GMT+8, 2025-12-26 00:49 , Processed in 0.109090 second(s), 18 queries .
