First power on of Dynasty 200!
发表于 2021-8-31 23:36:28 | 显示全部楼层 |阅读模式
OK I got my 6-50 plug installed but I don't have the 230v running yet so I used my pigtail to turn it on the 115v... I've heard these are noisy machines , and yes mine was noisy as well, but after I turned it off the noise stayed and went down a few octaves then silent ... Is that normal? Sent from my Nexus 7 using Tapatalk HD Attached Images
Reply:OK after a little homework , I read at the miller forum this is completely normal for it to make the noise after shut off... Something to do with the capacitors discharging...Sent from my Nexus 7 using Tapatalk HD
Reply:Yep.  Normal. Purrs a while after turning power off.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:It's got real bits of panther in it....that's how you know it's good.
Reply:Mine sure does make some strange sounds, has that electronic whistle almost that changes pitch when the cooling fan comes on and slowly goes away after shutdown. I thought it was weird at first but have gotten used to it.
Reply:Yes,Miller uses a "fan on demand",  the fan may come on when you first turn on the machine but will turn off while it's cool enough...even the(newer) Syncro's will be silent when the machine is not actually welding... By the way the Dynasty is a BAD ***  machine !!Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by DemonSpeederYes,Miller uses a "fan on demand",  the fan may come on when you first turn on the machine but will turn off while it's cool enough...even the(newer) Syncro's will be silent when the machine is not actually welding... By the way the Dynasty is a BAD ***  machine !!
Reply:The noise is different on 120V vs 240V too.
Reply:Originally Posted by 7A749You know, Terry. I think Shovelon, INC needs to set me up with one of those freebie demos........You have my address. The newest Dynasty 350 you have would be fine. Now THAT is funny. Well, not really
Reply:Finally struck an arc with the dynasty today, man was it fun hah! I haven't tig welded since 2007 so this was very awesome for me.O had to make up a 240v extension to get from the house to the shed but it seemed to work great.  Here's my first lap weld done on the machine, too much undercut on the top; using 3/32 thoriated and 1/16 filler. Attached Images
GMT+8, 2025-12-26 00:49 , Processed in 0.200621 second(s), 18 queries .
