My welding table (again...)
发表于 2021-8-31 23:36:25 | 显示全部楼层 |阅读模式
HelloThis is my first published project and it's welding table... I made it from 1000x1000x8mm steel plate. I bough it for cheap from neibour who has cnc plasma cutter, so I didn't cut those holes, but they can be used for clamping,... I was welding with 2,5mm 6013 rod at about 90-100 amps. Frame is made out of 50x50x2,5mm steel tubes. On the left side you can see my little telwin on homemade cart. On the right side you can see my old welding table. I'll stil be using it for dirty stuff, because I want my main table to be in clean condition. I'll be using it mostly for tig, so it will stay nice and clean !And sorry for my bad english...
Reply:Your English is actually better than some of the American born WW members.No need for apology.Nice table!
Reply:Originally Posted by joedirt1966Your English is actually better than some of the American born WW members.No need for apology.Nice table!
GMT+8, 2025-12-26 04:18 , Processed in 0.101185 second(s), 18 queries .
