where to find hand winch that climbes steel tube?
发表于 2021-8-31 23:36:25 | 显示全部楼层 |阅读模式
Looking at making something similar to this. It is a LCD display jack. I usually have to hire help to install displays but, this is something I am more inclined to make my self. The asking price probably feeds this guys family and yes, I would not mind ordering it but, I am very budget limited at this time. So, All I need is a source for the winch. The other stuff I can make from scrap steel.http://www.e-zspreadnlift.com/detailtv.htmThanks
Reply:Have you try a sheet rock jack
Reply:http://www.northerntool.com/shop/too...atchallpartial
Reply:looks to me like the winch pulls in black webbing that is attached to the top of the pole...I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:Originally Posted by T E BHave you try a sheet rock jack
Reply:Boat trailer winch mounted on the tube with a pulley at the top. Cable runs from the winch over the pulley and down to the TV holder sliding on the tube.  Rachet pawl on the winch holds the load.  Tube is hinged to the base allowing the top of the tube to bear against the wall.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Adapt a pump jack that guys use to side houses with. The old ones climb wooden double 2/4's while the new style is more expensive but climbs and aluminum tube."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by nadogailBoat trailer winch mounted on the tube with a pulley at the top. Cable runs from the winch over the pulley and down to the TV holder sliding on the tube.  Rachet pawl on the winch holds the load.  Tube is hinged to the base allowing the top of the tube to bear against the wall.
Reply:I agree, it is basically the same as my camper shell jacks (light duty).Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:I go for the self braking winchs,@ TSC they run around 70.00 for the model i got.Very nice not having worry about it trying to kick back on you when lifting.
Reply:I used a worm drive winch from HF for my rotisserie, it stays where you stop it without brakes. ~$20 on saleCut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:you can geet a drywall lift for about $200 and modify the lift rack.
GMT+8, 2025-12-26 00:50 , Processed in 0.100125 second(s), 18 queries .
