Well, Castweld, it's ugly----
发表于 2021-8-31 23:36:23 | 显示全部楼层 |阅读模式
--- but I think it will hold. All I had was one 1/8" nickel rod, didn't really want to buy anymore as I don't know when the next cast repair will show up. I peened it w/ the needle gun real good. With 2/3 of the hole still in the block I don't think there'll be much stress on it. I stacked oversize nuts and washers on the bolt and finger tightened it down. Clamped the piece down after putting the bolt in.                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Looks to me like it'll work just fine Mike. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:They will take points off at the next car show..It will work and that's all that matters....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Time to change that frost plug too while you are there. How did you do that? I assume the bolt was put in then welded but how did you not weld the bolt to the block ( just curious)?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:He still had the piece that broke off http://weldingweb.com/vbb/showthread.php?t=57555 (3rd photo) which he welded back on the block with the described bolt holding it in place.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55He still had the piece that broke off http://weldingweb.com/vbb/showthread.php?t=57555 (3rd photo) which he welded back on the block with the described bolt holding it in place.
Reply:If it works it does not matter how it looks, and if it has to look good..... thats what grinders are for!PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
GMT+8, 2025-12-26 00:50 , Processed in 0.081696 second(s), 18 queries .
