TIG is not as Ez as I thought
发表于 2021-8-31 23:36:20 | 显示全部楼层 |阅读模式
Yesterday my bud, who is a good mentor and friend was repairing an Al offroad bike frame for a guy.  He set up his large in shop Miller TIG welder, watercooled.  The item was powder coated so he took a lot of time to remove that and then with me watching up close he welded a broken cross brace back in... he has welded on this frame at other places before.  He showed me a few tricks and handed it to me, and on a piece of scrap of course.  I did ok, and it reminds me some of heavy soldering or brazing.  I blew it out twice in about 2 inches of practice. Using the foot pedal and manuvering the tip and watching the rod...big fun  Ya don't touch the tip with the rod that messes things up big time.  Well like all good things it would take a lot of practice to get steady and good at this.   For a good ex: Go see HappyBob and his boat accessories, TIG,  hmmm that R sumthin.Last edited by PapaLion; 04-18-2010 at 09:35 AM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Originally Posted by PapaLionYa don't touch the tip with the rod that messes things up big time.
Reply:All you need to do is get comfy and dont panic...Stay away from the coffee..Tig is done with your arms in a as most comfortable zone as you can get...Use anything to get that way..It's like drawing on a sheet of paper...Comfortable hands....right?Don't be afraid to use a say block of wood to rest your hand on to get the torch in a comfort zone that you can work with...Be at ease.Go with the flow...No need to panic..Now just do it....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:zap.....itis amazing what happens when you get confy and relax.  in the beginning, I was always a bit anxious when I would tig......and as funny as it was, I would forget to breathe.  lol.  without realizing it, I'd strike an arc and was so focussed on the arc that I never realized that I was holding my breathe.
Reply:Thanks guys, I'm going to keep practicing because it is a very keen thing.  Don, my bud, looks 1/2 asleep and sitting but I was kinda' wired  I'm going to hang around anytime he uses the Miller and see if I can get a few minutes on it.  ? Is SS as difficult as Al or easier ya' think?Breathe, ya that would be good.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:P-bear,I'm a newbie at TIG but it's getting better.Zap is spot on re comfortable position...if I'm holding the torch by the handle and my hand/arm is unsupported, the weld looks ragged and the probability of dipping the tung is way high.  If I'm holding the torch sort of like a pencil (up close to the cup) and I'm resting my arm on something, the weld looks a lot better.  I make a few practice runs with the torch (just move the torch...no heat) to make sure the path is clear with no hang-ups.I've also found that if I loop the cable over my shoulder it takes the weigh off the torch and I can move more smoothly.Also....work piece at the right height...chair/stool at the right height...get comfortable. And like you, I was holding my breath but now I'm starting to relax.I don't know if this is correct but I get the tung right up close to the weld...1/16" to 1/8"...so a steady hand is a must.  I'm 58 and a avid coffee drinker so I need a the help I can get.I still have a problem with my torch hand glove getting hot.  I'm using Tilman deerskin gloves so I can feel the filler rod but they don't have much heat insulation.  I tried some heavy "welding" gloves but couldn't feel anything...torch, filler, nothing.  Plus, those gloves got so hot one of the fingers caught fire  (remember the cigar scene from the Mel Brooks Frankenstein movie).  Anybody got any suggestions on how to keep the gloves from getting too hot?Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
Reply:if you weld the filler to the tung you will have to stop and fix it, then it can cool down...works for me..i can tig weld with no glove on the torch hand...
Reply:Originally Posted by PapaLion Is SS as difficult as Al or easier ya' think?
Reply:Originally Posted by PapaLionThanks guys, I'm going to keep practicing because it is a very keen thing.  Don, my bud, looks 1/2 asleep and sitting but I was kinda' wired  I'm going to hang around anytime he uses the Miller and see if I can get a few minutes on it.  ? Is SS as difficult as Al or easier ya' think?Breathe, ya that would be good.
Reply:Originally Posted by BTDI still have a problem with my torch hand glove getting hot.  I'm using Tilman deerskin gloves so I can feel the filler rod but they don't have much heat insulation.  I tried some heavy "welding" gloves but couldn't feel anything...torch, filler, nothing.  Plus, those gloves got so hot one of the fingers caught fire  (remember the cigar scene from the Mel Brooks Frankenstein movie).  Anybody got any suggestions on how to keep the gloves from getting too hot?
Reply:Well I went and registered today at Az Western Jr College... WLD-106~section001 ~ Instructor: Dept Head Colton meets 9:30 Am to12:25pm for class and 12:35-3:30pm for lab/shop... hmm  where zactlee is the LUNCH break in this deal.  Meet for a month straight  2x a week beginning 06/02/10. Class Description: Techniques in Shielded Metal Arc Welding. COURSE GOAL ~To develop manipulative skill in joining of plate by the SMAW process in all four basic positions,in a safe and efficient manner, utilizing the proper electrode, equipment adjustment and jointapplication.Cost: ~ $153  Summer School? Have I forgotten the pain of summer school? apparently so.   Personal note to self~ Those beautiful young gals all over the place have no interest atall in you or your friendly smile~ believe it!  OkeyDokey then  More to follow.. I did NOT register for the Tuesday Thursday class for TIG.  One battle at a time  But the machines arre there and hopefully I'll get a little pracitce time TIG~in' too.Last edited by PapaLion; 04-21-2010 at 05:36 PM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:P-lion,The lunch break is from 12:25 to 12:35....rtf...uh...course description.Seriously, I envy you.  If I had the time I'd sign up for a welding class in a heartbeat.  I have checked around here and the welding courses (Houston Community College at least) are not real plentiful.  Now computer programming and office skills I can find on any campus anytime but industrial trades are few and far between...and this is Houston, Texas.  I hear they will soon be phasing out metal shop in the high schools.  Oh well.Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
Reply:Originally Posted by zapsterI just use a 1001MIG glove on my torch hand..Nothing on the filler hand..However I do go thru a glove a month from "Melting" the fingertips on it..You get used to it after awhile.....zap!
Reply:BTD, maybe this is what ya' call... "hungry for an education".   Houston is such a great city one of the best in Texas..  Music arts, NASA, Med Centers and more.  Do U know the official Houston city flower?  unfortunatly, it is moldLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Originally Posted by PapaLionBTD, maybe this is what ya' call... "hungry for an education".   Houston is such a great city one of the best in Texas..  Music arts, NASA, Med Centers and more.  Do U know the official Houston city flower?  unfortunatly, it is mold
Reply:Yes true, other great things I had forgot  about that bustlin' city  Don't gotta go duck hunting in Houston, Mosquitos are bigger and more sporting.  I spent my youth in Phoenix... u know Phoenix, LA but NO beach.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Originally Posted by BrettZap I do realize that you  are not actively advocating unsafe work practices , but you saying as an experienced Welder (OK Weldor in the US) that you do not use gloves I feel irresponsible.Brett
Reply:I TIG all the time without gloves, unless its HF AC, I tend to get little zaps when i build up enough static in me. Is it recomended, no but I know a lot of people that do it.Syncrowave 350Coolmate 3Millermatic 251Spoolmatic 30A
Reply:I'm a newbie at TIG also, and will vouch for what Zapster said. STAY AWAY FROM COFFEE!! lol! I drink coffee before I got to school and every time I have to try and flush my system because I get the shakes. Get as comfortable as you can get with out falling asleep. lol!www.thefusionsolution.com
Reply:Chinese crap including diesel parts on "MY" thread!  Fricking gawl of this spammer.  Where is the justice   zhu_2012 eat my shorts.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:get comfortable and steady. another big thing is setting your stick out right. If you use a shorter stick out you can usually rest the cup on the work piece.  That's the difference between constantly dipping your tungsten and being able to keep a narrow gap.  Used to get me thru on the harder out of position joints all the time. and yah a class will usually get you there much faster and cheaper. That's been my experienceWelding EngineerCertified Scrap Producer
Reply:My biggest issue right now is T joints for TIG aluminum.. pita.www.thefusionsolution.com
Reply:damn I need to cut back on the coffee then...
Reply:Class starts in three weeks, I went out and got a new pair of gloves...In Harmony  Mn ya' freeze without coffee, I'd just figure it as a hazard of the game there.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:WooHoo, I'm getting excited! Tig class was tough for me,  and aluminum gave me (still does) the heebeegeebees. Stainless was probably the easiest to get a handle on.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDannyJust aluminum T joints for me.. I finally got the garage wired up so I can now use my TIG welder at home. School is done for me.www.thefusionsolution.com
Reply:Well, I'm just about ready for my summer welding class that starts in a week  at the Jr. college. AWC.  Professor Colton is real picky about safety, I mean like borderline freaky. I've  been in his casting class and a few others.  So... Welding cap "Yuma Weldors" care of  Dadscaps.com /Donna. BIfocal safety glasses from Lowes,  Prescription Earplugs which U can hear talking thru easily but they don't allow harsh noise in, and the coup de grasse>>>(per a thread here, thanks much!)  the new 3M Half Facepiece Respirator 6000 Series with Particulate Filter 1000s installed. (I have real bad asthma so I'm hoping this will help a lot). The shirt is an older Levis long sleeve very heavy cotton cowboy shirt which has some Rustoleum primer and some other? unknown stains.  Tomorrow, I'll add a pic or two of the keen elkskin gloves from Airgas and what I think you might find to  be a unique kind of carrying case for my helmet.  Since lunch is a whole TEN minutes long I plan to stretch my luck and abuse my friendship with the Prof a bit... and take a small cooler full of goodies to eat as I please  I don't know if we are welding inside or outside... It will be hot you can count on that, but given a choice I'll be outside.pic is:   ~~~~TAKE ME TO YOUR LEADER~~~ Attached ImagesLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:You look like you are ready for surgery..Calling Dr. Howard..Dr. Fine...Dr. Howard........zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zapster,)  glad U saw that Dr, surgery... these are scary words around me, they love to "practice" on me.....meanwhile,  a guy came into my store years ago, a Canadian, and he had built a steel skeleton frame which copied a Stratocaster, the neck and pickups etc were stock.  Played ok, was kind of heavy... Seems Al would be the better choice with TIG maybe?  a Tele would be my choice,  Cold bend the frame or U would need heat? I dunno. Show the welds, don't cover anything up, leave it a skeleton...  hmmm   what Al? if U want it shiny 5051 maybe  but it'd be bar stock I guess... 1 /8" x1 3/4polish it before , or after?   anodize it.  Lot's of choices here.   I've built maybe 100 Teles, but never one made of  metal.enjoy,   R I a Doc? probably House> U know moody,  rude weird Doc...Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:gloves are pretty common I suppose... ? where do the Chinese GET Elkskin to make 'em???hmmmThe helmet case> yes, that is a cat littler plastic bucket that I had... which fits the helmet nicely, and the towel keeps it padded a bit.  Probably better ideas but it works for me.. cost was exactly right too> free. Attached ImagesLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Elk= Cantonese for kitty. They just been died yerrow.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:I was thinking either Russian Elk maybe or I dunno, water buffalo... I'm not sure in China the concept of "elk" really sinks in. No matter, they feel aok.  I don't speak Cantonese thanks for that clarity. My favorite pair of worn out boots are some old Elk Noconas... been 1/2 soled 2x I think.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Plenty of welding classes in Houston!  Took mine at San Jac last summer.  College of the Mainland in Texas City has them too but that's a bit further down the road.  Houston Community College also has them.Also, I've personally had issues welding with a light colored shirt on.  Seems to reflect a lot and drives me crazy.  I always wear a darker color.  I know it's the welding position I'm in too.FuelBoy-----------Lincoln SP-135 PlusLincoln Precision TIG 225
Reply:Houston, as mentioned before, the Jewel of East Texas. That's a thought, I can dig out an old dark blue one, and I'll give them both a try.   Last time I was really in college/grad school was 1975-6.... hmmm so this is for fun, BUT I enrolled for the grade, no way I'll take it as "geezer college" for no credit (even though the tuiition was lower, no way!). Paid my $ and I WILL get graded.   Maybe my last career will be as a pipewelder?... hmmm,  62 year not too healthy, older sorta wobbily pipewelder... I might should re-think that.  Betcha my wife will not be ok and sign off on that either,  I KNOW her.... and she likes to spoil all my fun   So, zactlee how will I ever justify an SA200?  I dunno.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:First day of class>  One banana, one triple decker peanutbutter/Stawberry jam/honey sandwich, 1 chips, 1 crackerjack, 2 waters.  Safety film, (good one I learned some).  Safety quiz,*(see below).  Went over gear to bring to class, I'm ok there,  I will be able to weld outside if the booth gets too foggy. 16 classmates, mostly young, mostly Mexican, a few X marines and me.  I won the contest for the only guy who has been married longer than Al Gore, and the contest for having on a pair of boots older than everyone in the class, but the Prof. Overall, excellent, highly recommend it, this is going to be like driving on a paved road after a 1000 miles of dirt. enjoy,  * Safety ?> What is the maximum safe pressure in p.s.i. for Acetylene use.  and why? a. 5b. 10.c. 15d. 25kool, now I know.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Nice to see another triple decker w/ P.B. and jam and honey eater!!!! 200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:harder than it looks? This explains the thousands of rookie tig questions that get asked.
Reply:Awright, Poppa wheres the class updates?  By now it should be down and dirty and the Prof telling you bad things that hurt you feelings.  By the second week, I was breezin along and got my feelings hurt when my coupon was "selected" for destructive testing.  It looked so good, I figured noway it would fail.  Oh no, not enough fusion in the root you say? and Blink it snapped apart like a booger weld.  Damn my feelings were hurt.  But I kept it up and no more Blinkies.  Just keep practicing, it gets better and easier with time.  Now my stuff is pretty and it dont break.  My feelings still get hurt, but the wife is in charge of that now, and she is the best when it comes to that,  Been together longer than Al gore too!!!I'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:That'd be this week  If I'm not too down in the dumps I'll take a pic or two... Poor ol'  Al....that "change" can hit a fella like a brick... ya' gotta just suck it up and smileLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:It was about 107+ this afternoon, but I was in the shade and having fun with 6010 and a little 7018.  The Miller fume extractor is brand new to the College, and I get to try it out first; that thing is GREAT!!! No fumes, none.  very kool.  I am in the breezeway, don't care much for the welder itself but who cares for a coupla weeks... and the course is a lot of fun.  Wednesday we get to do a lot more, today was ... ~see if you can stick the 6010 electrode to the nice steel. or set the tip on fire like a match.  I was able to do that very well... then it was see if you can drag it along the steel... that went poorly, this is actually my 2nd piece of practice scrap making buttons and such.  the Prof is still laughing at the first one... so it'll take a lot of detail and practice. For me,  my big problem is to get up to SPEED, I like to dawdle with MIG  but 6010 is really not into that I find  TRAVEL SPEED > Mach II  There are about 16 booths, so I could be set out here in the breezeway most likely anyways, we have 18+ students. Meanwhile:Young student walks by and asks:"Why are U welding out here?"I answer, with a straight face:" Oh, only the old 1/2 blind guys who can't breath are supposed to use this table".  Student: "Ok then".enjoy, Attached ImagesLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:PapaLion,You can wipe the labels off of your free helmet case with a rag and some lacquer thinner. It won't hurt the plastic, but takes the labels off with just a few wipes. I've saved a bunch of those pails and use them for everything, but I only remove the labels from the ones that will be seen in public. CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:I like them too, I store seed in them etc... handy and cheap.  Laquer thinner, could try that, thanks.BretLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Class is kicking my butt IF I say IF, I were paying for the materials I'd be broke by now... but slowly and surely the 6010 and I are making friends... not good friends just friends.  I have seen about a bucks worth of dimes stacked by me  so far  I'm doing fine in the written tests, Safety 100% and about 85-90s on the rest.  BUT, that does not transfer to the shop yet at all.  We have a sub for a week (the retired dept head, Our teacher is gone to a welding contest in Kansas City with some students),This fella is also a good teacher and friend of mine for 20 years... and is good at explaining and showing me my errors... so it goes along. I am behind on the topic projects but so what... I'm here to learn 6010 and 7018 and correct positions and technique.  Very slowly there may be light. It is very much like learnig to  play guitar... when I play (and I'm just pretty good. no whiz kid).. some guy will say for ex: "how do you do that all at once?".. I like 2 and 3 finger bluegrass acoustic picking, Doc Watson style stuff.. and I have to recall that I spent more than a year regularly trying to SLOWLY get that down... just to be able to do it at all, much less do it well. So this is similar, practice will be needed and practice with a point. I am doing the exercises over and over till I want to puke, but absolutely needed in my case, I'm obviously not a natural Maybe a few pics Sunday if i can.Gone to San Diego for a few days of rest... enjoyLast edited by PapaLion; 06-16-2010 at 07:23 PM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Yeah that stupid No Cash err? Child Left behind didn't help either.    I applaud Obama for basically scrapping it and going with College or Career at Graduation as the new national education goal.   Hopefully it will bring a lot of the skilled trades and apprenticeships back into the high school settings.    Not every student is cut out or wants to go to college and we need to offer other career paths for these students....   with mutiple learning styles some just do great at hands on skills but may not be great at the book worm stuff...  Originally Posted by BTDP-lion,The lunch break is from 12:25 to 12:35....rtf...uh...course description.Seriously, I envy you.  If I had the time I'd sign up for a welding class in a heartbeat.  I have checked around here and the welding courses (Houston Community College at least) are not real plentiful.  Now computer programming and office skills I can find on any campus anytime but industrial trades are few and far between...and this is Houston, Texas.  I hear they will soon be phasing out metal shop in the high schools.  Oh well.
Reply:Sounds like youre having fun Papa!!!!  I knew you would Hee Hee.  I really like the cat litter helment bag idea, I would write "Used Litter" on it an no one would ever think to look in there and steal my helment.  6011 is yer freeeend, yeah and so are hemoroids and constipation, but it will get better.   Seems like Community College is still the same old same old, but it does teach a lot for the money, I'm pretty sure I got my $'s worth in metal too.   Have fun and show us some pics when ya get em.BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:Originally Posted by soutthpawYeah that stupid No Cash err? Child Left behind didn't help either.    I applaud Obama for basically scrapping it and going with College or Career at Graduation as the new national education goal.   Hopefully it will bring a lot of the skilled trades and apprenticeships back into the high school settings.    Not every student is cut out or wants to go to college and we need to offer other career paths for these students....   with mutiple learning styles some just do great at hands on skills but may not be great at the book worm stuff...
Reply:Got up before dawn, went to the ranchita/shop, fed and/or watered everybody (7 goats and 25 baby chicks and 4 hens and a rooster, 100+ Birminbgham Rollers, and 90 young pomegranate trees)... and then pulled out the WeldanPower 225, checked the oil and gas and got out my 6010. Suited up ( I'm safer now anyways), then, I took some scrap and started in.  First, it is 6010 1/8" Radnor which has been dissed a bit here,  but for me in this case it seems easier to start than whatever we're using at school.  Next, is it my wishful thinking??? seems much better overall.  I think the W/P is working well and for me, much better than the Inverter based machine at school.  I'm still lousy... but the effort seems more relaxed overall.  Tomorrow morning  I'll hopefully go again, it gets to over 100 by ten AM and sunny... so that limits the fun a bit. practice makes perfect... well I"m just hoping it gets me thru for nowLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Tomorrow is another class.. the class lab time goes fast,  for me to go 5-6 hours straight thru, in the heat, few if any breaks etc... is not so good or ez... but I just do it and the younger guys kinda tuck me under wing and are aok. I'm almost aceing the tests, like 19/20 on the last one and yet barely getting thru the shop/ lab.  About 1/3 of the class seems to be unconcerned, they either are doing average or are too bizeee texting their girl to worry (I don't have that problem, I got no texter or young crazy demanding girl thanks much).  About 1/3 are clearly ahead of me,  and 1/3 seems a little lost, are behind, or not doing to well, and/or have mentally given up that'd be my group  I plan to go down in a blaze of 6010 fumes, no damn giving in here I'm used to leading a class in all areas.. so it is a humbling experience, and well deserved.  When you do 6010 like I am so far ya;' gotta be humble.I purchased some material of my own (old men have an edge, called an extra $20 or 2 for  material to practice with This morning early I made up several project tack ups in advance  at my shop using the W/P 225 and 6010 of my own.  This takes me a good 45 minutes each so I've got 4 ready that saves me a coupla hours in class.  I guess these are "coupons" of a sort, not for a test just to use for the projects in class. I'll do the 7018 in class for sure.fillet weld  flat project 6 one side with 6010 1/8" and the other side will be 7018 in class. The other project  is a prepared piece to weld 6010 fillet and overlaps... # 10 I think?Hmm  well the main thing is to figure what to take for snacks/lunch tomorrow Attached ImagesLast edited by PapaLion; 06-22-2010 at 11:26 PM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:I don't get to practice that rod enough. Burn a circle, whip forward to allow the first bead to freeze, then back for the next bead... Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Thank U Tangle... it is better than last week... from pathetic to miserableLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
GMT+8, 2025-12-26 00:50 , Processed in 0.102943 second(s), 18 queries .
