Profax spool gun problem
发表于 2021-8-31 23:36:18 | 显示全部楼层 |阅读模式
Hi Folks.Great site, with lots of great advice. I have been reading posts looking for an answer to my problem, but can't seem to find anything similar... So here goes.I have a profax 200 spool gun and when I finish laying a bead on aluminum and release the trigger, about 12 inches of wire continues to spool out, then stop. I inherited this setup from my Dad and I know he had the same problem and farted around with the thing constantly trying to get it to stop spewing out that last shot of wire. Otherwise the gun works great, but it would be nice to clear this up if possible.Thanks in advance for any help!
Reply:I have no solution, but i do have a question that may help others, does it spew the extra wire with every trigger pull or only after a decent sized bead?
Reply:Call profax.  Their tech support is very knowledgeable and they r here in the USA...   also need to know what model control box or welder its running from.  There is no direct connection from the trigger to the motor on a profax 200.  So the control box or welding source if its a direct connect like on an ESAb is going to be the source of the issueTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by Crash5291I have no solution, but i do have a question that may help others, does it spew the extra wire with every trigger pull or only after a decent sized bead?
Reply:Originally Posted by soutthpawCall profax.  Their tech support is very knowledgeable and they r here in the USA...   also need to know what model control box or welder its running from.  There is no direct connection from the trigger to the motor on a profax 200.  So the control box or welding source if its a direct connect like on an ESAb is going to be the source of the issue
Reply:Most likely you can use it for steel.   I'm not familiar with that power source or who made it for Linde/Ltec.  Esab made a lot of their stuff.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-26 00:50 , Processed in 0.092151 second(s), 18 queries .
