What do these all mean...UA51, UA41, UA21, UA2 and UA1.I know some of them are weld tests but exactly which ones?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:This should help you out http://uatravelers.com/UA-WeldCerts.htmlIm not really familiar with welding tests i read up on some 3G which means vertical position groove i believe... Although im confused with why 6011 has a 1 if in a test a 1 is considered flat position but in a 6011 rod the 1 means it's for all positions? You mind clarifying that up for me if you can =) Thanks |
