Snap on bluepoint plasma cutter help
发表于 2021-8-31 16:58:45 | 显示全部楼层 |阅读模式
A friend bought this plasma cutter and its isnt working. It looks like someone snipped something off the bottom corner of the circuit board. Does anyone know where to get a new circuit board or get a print of the board so I could replace whats missing? Im assuming it quit working and the last owner found a burnt resistor or something and cut it off to find a new one and gave up on fixing it. The machine is 115V and 25amp. Attached Images
Reply:that plasma cutter is actually manufactured by Cebora.... other model names include SNAP-ON YA-2225   MARQUETTE M12155   CENTURY 82021   MATCO PCS21    PROARC  2500if you get it lined out heres a place that sells tips and stuff for it..  you might call them and ask if they do repair work or if they know of anyone,,, http://www.weldmart.com/SNAP%20ON%20...ING%20PAGE.htm they also sell an updated torch kit for it. if you get it repaired and decide to keep it i would do the torch upgrade, it turns it into a pilot arc plasma..you might try this place http://www.800abcweld.com/store/?crn...=1&action=show its the place thats listed on the front of your machinehere is a link to a service manual http://www.800abcweld.com/pdf/plasma...ice_manual.pdf  also, being since Lincoln Electric bought century you might try Lincoln.Last edited by brucer; 07-28-2011 at 07:33 AM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:i done some digging, found this stuff..  from what i found on the internet parts are available..  let us know how it turns out..you have to use the century 82021 , marquette M12155 or matco PCS25 model numbers.. i found this on Lincoln Electrics site http://www.lincolnelectric.com/asset...er%20Index.pdfservice manualhttp://www.lincolnelectric.com/asset...5svcmanual.pdfparts listhttp://www.lincolnelectric.com/asset.../RPLM12155.pdfLast edited by brucer; 07-28-2011 at 07:53 AM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by bruceri done some digging, found this stuff..  from what i found on the internet parts are available..  let us know how it turns out..you have to use the century 82021 , marquette M12155 or matco PCS25 model numbers.. i found this on Lincoln Electrics site http://www.lincolnelectric.com/asset...er%20Index.pdfservice manualhttp://www.lincolnelectric.com/asset...5svcmanual.pdfparts listhttp://www.lincolnelectric.com/asset.../RPLM12155.pdf
Reply:You call always try HTP America and a new place called Cebotechusa.comI have found both places very helpful.
Reply:Anyone ever find a manual for the MAC/MATCO PSC25 by chance?Wondering also, what the Lincoln model is called.  Anyone know by chance what the Lincoln branded model was/is?Thanks in advance for your time and support.  Originally Posted by Michaeljp86That service manual has a schimatic of the circuit board but its different from this one. I appreciate the help, I think were getting a little closer to getting this going.
Reply:Looks like the links are broken.  Did you or anyone you know happen to save a copy they can share? Originally Posted by bruceri done some digging, found this stuff..  from what i found on the internet parts are available..  let us know how it turns out..you have to use the century 82021 , marquette M12155 or matco PCS25 model numbers.. i found this on Lincoln Electrics site http://www.lincolnelectric.com/asset...er%20Index.pdfservice manualhttp://www.lincolnelectric.com/asset...5svcmanual.pdfparts listhttp://www.lincolnelectric.com/asset.../RPLM12155.pdf
GMT+8, 2025-12-18 16:19 , Processed in 0.098832 second(s), 18 queries .
