welder cable size
发表于 2021-8-31 23:36:06 | 显示全部楼层 |阅读模式
A friend brought over a Lincoln 225 to see if I could fix it as it wouldn't run. After finding a loose wire I noticed the welder had 25 foot leads of number four gauge wire.Isn't that kind of light wire for a welder that can weld at 225 amps. Shouldn't it have #2 wire or smaller for the leads?
Reply:Here you go.http://www.islandsupplywelding.com/w...le-chart-3.htmDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I would have #2 on it.  Miller recommends #2 for up to 50' at 250 amps.
Reply:Originally Posted by CEPHere you go.http://www.islandsupplywelding.com/w...le-chart-3.htm
Reply:Originally Posted by kctgbThanks for the info.After looking at the chart it looks like the 4 gauge leads will work ok.
Reply:As others have said, the #4 is fine. "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
GMT+8, 2025-12-26 00:51 , Processed in 0.069274 second(s), 18 queries .
