overhead stick with 6013
发表于 2021-8-31 23:36:05 | 显示全部楼层 |阅读模式
Hi guys...just looking for some tips on overhead fillet and grrove welds with 6013s?Any advice tips would be greatly appreciated..
Reply:Depends on what problems you are experiencing.However - I run into trouble if I forget to keep forcing the rod into the puddle.  Feels like forcing because of fighting gravity.  Long arc = worm holes.Amps should not vary much from welding regular grooves or fillets.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I just find the weld to be dripping out...prob cuz I had to much angle on the rod
Reply:Originally Posted by PaddypowerI just find the weld to be dripping out...prob cuz I had to much angle on the rod
GMT+8, 2025-12-26 00:49 , Processed in 0.107114 second(s), 18 queries .
