Hobart tr-250-Hf HELP??? almost dead
发表于 2021-8-31 23:36:05 | 显示全部楼层 |阅读模式
So let me give a little history on my welder.  Purchased several years ago used and welded fine for a long while. All of a sudden started tripping my breaker intermittently then it died all together. The HF worked but would you could not start a weld or raise the weld current when using the remote.My dad traced the issue to some resistors in the rear which he replaced.  The welder was then tested only stick welding which is did fine. (no pedal on local)I now am trying to tig weld but the thing keeps tripping the breaker. It will trip at the first moment you press the remote pedal.      Hf still seems to work if you put it on continuous but do not press the pedal.any thoughts ??
Reply:Someone ..... Anyone .......HEEEEEEEELPPPP
Reply:I had one of those and it was a good machine until I pushed the limits and fried it..First off..Does the lever that changes the polarity (Left handle looking at the machine) still function or is it "Stuck"??...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI had one of those and it was a good machine until I pushed the limits and fried it..First off..Does the lever that changes the polarity (Left handle looking at the machine) still function or is it "Stuck"??...zap!
Reply:What size breaker are you running?Some breakers just "Give Up" after being tripped every so often.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by Userkc14419Yes both levers still work.  They are getting a little sticky but both both move and work as expected.
Reply:Originally Posted by zapsterA little stickey COULD be the start of this...http://weldingweb.com/vbb/showthread.php...ghlight=HobartIf so then I have replacement parts.....zap!
Reply:Originally Posted by zapsterWhat size breaker are you running?Some breakers just "Give Up" after being tripped every so often.....zap!
Reply:I also forgot to ask... Any where I can find a full schematic???????
Reply:Ohh yeah one more question.  Is it normal to get a mild electrical jolt when you touch the electrode post and have the HF on ???thanks
Reply:????????
Reply:If you think its the switch replace it and if you think its the breaker replace it with new ( then you have spares).Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by dumb as a stumpIf you think its the switch replace it and if you think its the breaker replace it with new ( then you have spares).
Reply:Any other ideas or people to contact before I give this thing last rights ?????
GMT+8, 2025-12-26 00:49 , Processed in 0.098104 second(s), 18 queries .
