Frame for welder ?'s
发表于 2021-8-31 23:36:03 | 显示全部楼层 |阅读模式
Wanting to build a simple H or square out of 4" channel to place welder on.  In this frame if will put something for my leads at front of welder of course.  However, on battery end, I am wondering how far I should stay away from welder for the bottles.  ? is how much gap do I leave for the bottles between welder.  Just enough to remove battery???  Thanks guys.
Reply:Perhaps it is just me, but I am having just the slightest bit or trouble understanding your question.  In my mind, I would just place the bottles close to the welder and then remove them if you need battery access.  It's not like you should be removing it every time the machine is used.  Remember, a compact, efficient skid is a happy skid.
GMT+8, 2025-12-26 00:49 , Processed in 0.128721 second(s), 18 queries .
