water coming in cabinets
发表于 2021-8-31 23:36:02 | 显示全部楼层 |阅读模式
hey just wondering what everyone is using for weatherstripping to prevent water from coming in their cabinets.  any pics would also be great!  thanks
Reply:My roof prevents water from getting into the cabinets.
Reply:Would this be tool cabinets on your truck or kitchen cabinets in your house? If they're on your truck, would they be cabinets that you fabricated yourself? Pictures would help a lot here. A much better explanation would help too.If you made the cabinets for your truck and the doors are leaking, go to a store that sells the ready made tool cabinets and look at how the doors and the edges around the door openings are fabricated. In most cases they don't use any weatherstripping. It's all in how the door and the door opening are designed (a little gutter directs the water around and away from the opening).CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
GMT+8, 2025-12-26 00:50 , Processed in 0.095929 second(s), 18 queries .
