Snap On YA212A for Tig?
发表于 2021-8-31 23:36:00 | 显示全部楼层 |阅读模式
I have a Snap on YA212A welder.  I would like to set it up for tig welding aluminum, but I am not sure what equipment I need.  I think this machine was made by century.  What style tig torch do I need that will connect to this machine, and can I connect a foot pedal to it?Also, how do I determine what type of rod I need? I don't know how to tig weld, but I would like to learn how to weld cast aluminumThanks for the help
Reply:No aluminum TIG with this unit.  No AC, no high frequency.http://yabe.algebra.com/~ichudov/mis...spec_sheet.pdfOwners manual:http://www.800abcweld.com/pdf/ya212a...ers_manual.pdfService Manual:http://www.800abcweld.com/pdf/ya212a...ice_manual.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for the help.I guess there is no way to invert this one?Looks like it is going to cost me a little more to get started.Thanks
Reply:Just purchase a spoolgun and your ready to mig weld aluminum with this powersource.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I have a spool gun, but I've been told that Tig is the only way to repair cracked cast aluminum.Thanks
Reply:4043 wire and pre-heat.What is(are) the piece(s) to be welded?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-26 00:49 , Processed in 0.108315 second(s), 18 queries .
