Tig and humidity???
发表于 2021-8-31 23:35:59 | 显示全部楼层 |阅读模式
Anyone have trouble with tig aluminum and high heat/humidy? thanks jon
Reply:Yep.   Had the problem just today.  The helmet lens fogs up, and I can't see jack diddley squat.Who is John Galt?
Reply:Shouldnt be much of an issue since the atmosphere of the weld pool is your shielding gas for the most part. Might be fighting pre-weld oxidation a little more. I have had more issue with humidity in the shielding gas than anything, before installing line dryers. Hmmm unless your in a coastal area where the humidty is a bit "salty"....hmmm. But that should be cured with a good prep as well.
GMT+8, 2025-12-26 00:50 , Processed in 0.077583 second(s), 18 queries .
