Miller XMT 350 VS
发表于 2021-8-31 23:35:59 | 显示全部楼层 |阅读模式
ok guys teach me some more what is the difference between the XMT 350VS and the XMT 350 cc/cv the good bad and uglies please
Reply:from what I am reading the 350vs is not pulse capable, nor is it remote control friendly which means what to me in the real world.  Sorry for the silly questions guys but these inverter machines are new to me so trying to learn.
Reply:350 VS does not have provision for remote control.  Therefore the machine is very limited in it's tig capability.(no remote amp control)Lacks the capability to interface with the Optima control for pulsed welding.Without the remote control receptacle, you're limited to using a voltage sensing (VS) wirefeeder like the 8VS or 12 VS.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:The XMT350VS is for stick welding and wire welding with a volt-sensing arc-powered feeder only.  It is constant-current and constant-voltage with no remote capability.  If you're buying new, spend a few dollars more and get the XMT350CC/CV model instead, as it has remote capability for DC tig with a foot pedal or hand control and wire welding with a spool gun or remote feeder.  If you don't need the extra power or internal gas valve option, then you can save some money and get the XMT304CC/CV model, which has the remote capability too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thanks guys been shopping for a cc/cv xmt304 and came across the XMT 350 vs for $1400 I know compared to a CC/CV i seen priced it sounded like a steal but I rarley if ever stick weld.  Mig is my bread and butter anf Tig is on the horizon so I will continue on the Journey to find the XMT i need
GMT+8, 2025-12-26 00:49 , Processed in 0.159516 second(s), 18 queries .
