I have some 2017 square tube I want to weld with tig or mig anyone have any luck with either process? From what I have heard, Friction stir is the only way to go.
Reply:That alloy can be TIG welded, however you'll compromise the materials strength and corrosion resistance. It's also vulnerable to hot cracking.Check the link below for their recommendations on welding and heat treatment.http://www.suppliersonline.com/propertypages/2017.asp Originally Posted by craig161I have some 2017 square tube I want to weld with tig or mig anyone have any luck with either process? From what I have heard, Friction stir is the only way to go. |
