Mig welding 16 guage galvanized steel
发表于 2021-8-31 23:35:57 | 显示全部楼层 |阅读模式
So. It is framing steel. All I have is a MIG welder. I can get smaller wire different gas doesn't matter.I am thinking about going to either .023" welding wire.What do I do to clean up the galvanized steel?What about safety? Should I purchase a good mask?
Reply:Originally Posted by pyroracing85So. It is framing steel. All I have is a MIG welder. I can get smaller wire different gas doesn't matter.I am thinking about going to either .023" welding wire.What do I do to clean up the galvanized steel?What about safety? Should I purchase a good mask?
Reply:You could use .023 or .030 wire.  C25 gas.  Use a flap wheel or wire wheel to take off the coating about 3/4" out from where the weld's going to be.  Wear a 3M 6000 series mask with a 2097 or 2091 filter.Jack OlsenMy garage website
Reply:or you could just use fluxcore...
Reply:Run .030 or .035 fluxcore self shield wire and don't bother with cleaning the galvi.  Wear a 3M respirator with the pink filters and keep your head outta the smoke and you will be welding and feeling just fine.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-26 02:28 , Processed in 0.114612 second(s), 18 queries .
