matco welder help
发表于 2021-8-31 23:35:56 | 显示全部楼层 |阅读模式
I am just getting started welding I have a 110 mig setup and i am well aware of its limitations but with the current limits on the electricity in my garage and for my uses its what I will use I have searched and cant find any documentation on the welder its a matco no. wfwm a any info would be great I was also wondering about the capacitor mod and if its possible with my machine if you need any more info from me I will post asap thanks  I will try to put a pic of it up here tomorrow
Reply:Originally Posted by Jackdawson I have searched and cant find any documentation on the welder its a matco no. wfwm a any info would be great...
Reply:Originally Posted by JackdawsonI am just getting started welding I have a 110 mig setup and i am well aware of its limitations but with the current limits on the electricity in my garage and for my uses its what I will use I have searched and cant find any documentation on the welder its a matco no. wfwm a any info would be great I was also wondering about the capacitor mod and if its possible with my machine if you need any more info from me I will post asap thanks  I will try to put a pic of it up here tomorrow
Reply:it says right on the front Matco no. WFWM A I dont see a model number on it other than that. It has a serial number. I did try to research my equipment and found nothing thats why im posting on here for help sorry pic wouldnt load ill fiigure it outLast edited by Jackdawson; 03-05-2013 at 07:15 PM.
Reply:I think the newer Matco welders are some chinese imports now. I may be wrong about that but I remember reading somewhere about their welders being made in china.
Reply:On the back it has a sticker with a serial number of c957498.   model.number that is blank and a date code of.   082389
Reply:Okay, take a pic of the front of the machine.  Perhaps if we can see the voltage selector and/or power switch, it might help.  Also, take a few pics of the mig gun itself and the nozzle tips and defuser, etc....   It may be hard for you to find replacement parts for that mig gun itself.   Second, on the inside cover panel, is there any type of chart for your "settings"?Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by JackdawsonOn the back it has a sticker with a serial number of c957498.   model.number that is blank and a date code of.   082389
Reply:Jack, your welder is a 90 amp machine.  It came with a Tweco gun, probably a Mini Mig.  Duty cycle is from 100% to 20%.  Shows a 30' power cord, and apparently has spot/stitch settings.
Reply:Might be in here some wherehttp://www.centurytool.net/Century_E...ls_s/32808.htmEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Does it look like this ?http://centuryweldingparts.com/data/...1,%2083085.pdf
Reply:I tried to post a pic but i can't figure out how  it looks like the PDF that blue posted. Now I probably track down a manual for it. I know it's only 90 amp but I want to get the most out of it. It does have a 30 ft power cord and it looks pretty thin would bigger wire help and could I do the capacitor mod to this?
GMT+8, 2025-12-26 02:37 , Processed in 0.103411 second(s), 18 queries .
