looking for manual
发表于 2021-8-31 23:35:56 | 显示全部楼层 |阅读模式
i am looking for a manual for a airco 250 ac/dc heliwelder v  call esab they don`t have it .  thanks
Reply:IIRC, that unit was made by Miller, but I cannot remember the Miller Model.
Reply:the machine has a esab tag on it  . will try at miller thanks
Reply:If it's like this one, the guy has a manual.http://www.millerwelds.com/resources...O-Heliwelder-VOr try Arc Products in San Diego.Last edited by Oldendum; 03-07-2013 at 07:11 AM."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:thank you for the info . just sent pm to him.
Reply:Glad you found what you needed Keith.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:still looking for manual miller has nothing / the guy that post has`nt been on miller site for two years. so back to the drawing board. thanks
Reply:Off topic sort of, to get a Miller product manual they have a bit of a trick, found it interesting. You need the serial number to get the pdf, tricky way to manage their information.
Reply:Originally Posted by pepiOff topic sort of, to get a Miller product manual they have a bit of a trick, found it interesting. You need the serial number to get the pdf, tricky way to manage their information.
Reply:Pipe down  I was not knocking Miller  own a couple, however you are correct about model will work . I over looked that choice  for whatever reason.  Greg
Reply:first emailed miller with serial and code also manual #  also same with esab. they both replyed no manual.  looking for wiring for foot pedal and just wiring diagrams. did a google search with put things up 2 guys on miller that have not been on since 2010  . any info will help. thanks keith
Reply:no diagram  on inside;  found diagram in pedal . he never had the pedal hooked up. has a 6 pin plug. on machine  will keep looking. thanks
Reply:Have you checked with WESCO ? Ibelieve they have a store in Pcola.   Rod
GMT+8, 2025-12-26 02:27 , Processed in 0.091890 second(s), 18 queries .
