plasma cutting multiple layers
发表于 2021-8-31 23:35:55 | 显示全部楼层 |阅读模式
Coming up soon I will be doing alot of plasma cutting, just designs into sheet metal. Question for you guys is has anyone tried to cut a piece but have to sheets of metal underneath thus resulting in 2 identical parts and only having to cut once? would that would work or would all the edges fuse together?
Reply:I have done it with 1/8" and 1/4" but never tryed it with sheet metalwww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Works great, provided your plasma cutter has enough "horsepower" to cut now a thicker piece of metal.  If your plasma is only rated to cut (not sever) 1/4" for instance, doubling up that steel twice (1/4" + 1/4" = 1/2"), your machine will just make an ugly mess with an unsightly kerf and dross that looks like it came out of the Krakatoa volcano. Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:This is done often with sheet metal. The trick to best cut quality is to keep the pieces tight to each other with no air gap. I had a customer in Tx that would stack up to 10 pieces of .090" aluminum and cut them with the 260 amp Hypertherm high definition plasma  (HPR260XD).....always did the same parts so he built a steel weight that sat on top of the aluminum stack to hold them together. The parts were semi-round, about 8' in diameter. This process was a huge time saver.Jim Colt  Hypertherm Originally Posted by mike7466Coming up soon I will be doing alot of plasma cutting, just designs into sheet metal. Question for you guys is has anyone tried to cut a piece but have to sheets of metal underneath thus resulting in 2 identical parts and only having to cut once? would that would work or would all the edges fuse together?
Reply:The stack technique has been used with Oxy/acetylene cutting for years."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-26 02:27 , Processed in 0.093638 second(s), 18 queries .
