overhead mig welding
发表于 2021-8-31 23:35:52 | 显示全部楼层 |阅读模式
almost perfect example of a good looking weld. i had the gun on to much of an angle on the edge of the plate as you can see. it seems like it was plenty hot because the toe on the bottom plate fused into the metal (dont know if you can see it on the pics)i think it would be acceptable if the angle was corrected what do you guys think?? Attached ImagesLast edited by BlackGT97; 07-14-2011 at 12:28 AM.
Reply:cut in half Attached Images
Reply:better than i could do. Subscribed so I can hear the experts and learn stuff too.miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Almost perfect is a bold statement. =|Cut out a 3/8 inch coupon or two and bend them.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:no no no i said almost perfect example of a good looking weld. not a perfect weld. lot of descussion about good looking welds being bad. i posted this because this is a good looking weld that is bad
Reply:you should post what settings your machine was on and wire size.   what type of movement did you use and if it was push or pull etcTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:if i remember it was a lincoln power mig.( not 100 percent sure it was a stick and mig welder)volts 16.5 wfs 165 (around there)was a w technique -push- pause at the bottom of the w and go througt the top of the w
Reply:I had to razz you, couldn't pass it up! They look good.  You see that edge on the left side of the third picture? My semi-automatic class instructor would tell you to straighten that out. Keep that edge as straight as you can. Then he would say, "Give me another one."  At which point I would give him my best "deer in the headlights" look. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by jpmillerlot of descussion about good looking welds being bad. i posted this because this is a good looking weld that is bad
Reply:Looking at the undercut on one side, and the way it rolls over the edge on the other, it doesn't look like this was done overhead at all.  Looks more like it was done in a 2G position.
Reply:Originally Posted by jpmillerno no no i said almost perfect example of a good looking weld. not a perfect weld. lot of descussion about good looking welds being bad. i posted this because this is a good looking weld that is bad
Reply:I think the plates were horizontal like you suggest, but he welded under the lap rather than over like you would in horizontal. Tecnically this would still be overhead, just it's not the usuall "flat"  overhead lap that would be my 1st thought..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:it was welder overhead like thisLast edited by BlackGT97; 07-15-2011 at 10:50 AM.
Reply:Originally Posted by weldbeadwhy do you say its bad?seems to me the weld is good, maybe the joint design should have had some space between the plates or some bevel..
Reply:Originally Posted by DSWI think the plates were horizontal like you suggest, but he welded under the lap rather than over like you would in horizontal. Tecnically this would still be overhead, just it's not the usuall "flat"  overhead lap that would be my 1st thought.
Reply:.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:this is how mine was set up (typical overhead lap)
Reply:i see it now.. doesnt seem to be undercut, just didnt fill in at the bottom against the lower plate..
Reply:Originally Posted by jpmillerthis is how mine was set up (typical overhead lap)
Reply:arms were off the table. i tried it in a few different positions like elbows on the table then one elbow on the pedisal that the table and clamp slides up and down on. but with elbows in the air i seemed to have a lot more control of the gun.why do you guys seem to think i did this the easy way and posted it as overhead? i have nothing to gain by trying to impress you guys. if i wanted to impress you i would not have posted a weld with the work angle all jacked up.
GMT+8, 2025-12-26 02:27 , Processed in 0.125219 second(s), 18 queries .
