Mig wire question
发表于 2021-8-31 23:35:49 | 显示全部楼层 |阅读模式
I am a newbie whern it comes to welding and will be going through my first spool of wire.  What do you do when there is no more wire to feed?  Is the remaining wire just thrown out or is there a way use it all?Just asking because I am going to finishing it up in about a week .
Reply:The feed rips the tag end off the reel and runs it right up to the liner. Right there you're done. Cut the nub off at the tip and pull it out from the machine end of the liner and chuck it.
Reply:Toss it like a bad habitYou weld enough and you will know when save it for odds and ends weird stuff weld it like you own it
Reply:THROW IT AWAY.  John G.     SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:okay cool.  Could you use the left to TIG with?
Reply:Yes, A tig wire is a mig wire that has been streightened.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Hi guys,What about use push-pull torches? any body tried it before? Anyway, I will try it soon in my factory and till you about the results. If anyone have previous exoerience with this please advise. Thanx
Reply:The fluxcore left over wire I just throw away, it isn't useful for anything.  The solid mig wire I keep a few pieces around for bailing things up and other uses.  Have used it for thin tig welding too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:It can also be coiled up on a 2# spool for use in a spool gun for small jobs or to allow you to finish a job because you don't have another fresh big spool to throw in the machine.  We're only talking 12-15' of wire but if a couple sections allows you to finish up . . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:solid wire can tig or gasweld.
Reply:Originally Posted by KarateDocI am a newbie whern it comes to welding and will be going through my first spool of wire.  What do you do when there is no more wire to feed?  Is the remaining wire just thrown out or is there a way use it all?Just asking because I am going to finishing it up in about a week .
Reply:I use it for making loops to hang stuff for powder coat or painting. Smaller contact area then the PC shops meat-hooksGood for bailing stuff together too. I just wind up the left overs on my hand and put them in a drawer.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2025-12-26 02:28 , Processed in 0.099988 second(s), 18 queries .
