Thermal dynamics pakmaster 100xl plus buzzing
发表于 2021-8-31 16:58:45 | 显示全部楼层 |阅读模式
Hi guys, new here.Anyway I just picked up an Thermal dynamics pakmaster 100xl plus that was set for 460v 3 phase.I did the necessary things to switch it to 220v single phase by flipping the buss bar and connecting the little wire that lines up with the square 220v hole.Then connected the jumper from L3 to L2 according to the manual.Unit seems to work fine except it makes a buzzing noise from the contactor switch...Is it possible it needs a new switch or am I missing something?Thanks in advance for any help!
Reply:Well I fixed it tonight, all a guy has to do is remove the 2 nuts holding the contactor switch to the housing.Once removed you will see 4 small screws holding the metal base to the plastic switch.Once that's off the magnet coil assembly falls right out so be careful.A little 400 grit on the contacts to shine the rust off and she's good as new.No more buzzing.I gave it a shot of wd40 also to keep the corrosion at bay.Hopefully my post helps someone with similar issues.
Reply:If you ever need a pilot arc contactor for that beast I have one. As well as amp dial with the little board it's hooked to.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:Good to know!Hopefully I'll get a few years out of her before I need anything.
GMT+8, 2025-12-18 18:25 , Processed in 0.073339 second(s), 18 queries .
