Is this a good deal? Old Lincoln SAE 300
发表于 2021-8-31 23:35:43 | 显示全部楼层 |阅读模式
Old SAE 300 for $500?
Reply:Or this?
Reply:Originally Posted by rschreckOld SAE 300 for $500?
Reply:That SAE 300 looks well cared for,if you have 3 phase power it would be the best stick machine you ever used.  If I had the I would I own one.
Reply:The reason it's only $500 is because its a 3 phase only machine.As stated, if you have 3 phase power, you wont find a better performing or smoother stick welder. It is also a very good scratch start dc tig welder.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-26 02:37 , Processed in 0.092098 second(s), 18 queries .
