Transit Tripod Back on The Level
发表于 2021-8-31 23:35:42 | 显示全部楼层 |阅读模式
One of the cats must have used it as a jumping off point for getting down off the top of the garage frig.  Found it knocked over on the floor a couple weeks ago and a pin for one of the leg pivot castings broken off. Finally got around to looking at fixing it this afternoon after finishing up getting a Weldanpower 150 back up and running for a guy at work but that's another story.TIG'd it up with the 180 SDCurrent set to 180Balance for maximum cleaningArgon at ~17cfh3/32" red1/8" 4043 fillerTwo pieces cleaned and ready to go back together.Back together and cleaned up with a softpad for adequate clearance.The ugly side.  Basically filled the cast cavity in on the right.to get to the backside of the joint.Back in place on the base.All better and "back on the level".Thanks for looking.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I just picked one of these up off the road the other day, its amazing what u see on the interstate but when everyone is runnin 80 its hard to slam on your brakes sometimes , i happened to go lucky that day LOLI forgot how to change this.
Reply:I'm surprised it was still in one piece but I know what you mean about seeing stuff on the highway and unable to do anything about it.  Safely anyhow.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:We like to say "You can't see it from the stands"...As long as it works all is good....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterWe like to say "You can't see it from the stands"...As long as it works all is good....zap!
Reply:Good job By the way!I forgot how to change this.
Reply:off subject ...when out of town working, "Cant see if from Springtown"Nice job on the repair, alot of folks probably would have just bought a new one.
Reply:Nice repair Duane, good as new. I have a tripod here looks very similar, looks like a heavy duty tripod, nice and solid as it should be.Just curious as to what you set on top of that tripod.  Level, transit, theodolite, laser?  For myself I have an old Brunson engineers transit which I no longer use after I bought a used Sokkia digital theodolite.  I'd like to buy a laser so I could do some of the grading by myself, but haven't found a great deal on one yet.Use my stuff for grading and laying out excavations and footings."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Looks like a tripod worth trying to save. You got it done."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
GMT+8, 2025-12-26 02:37 , Processed in 0.089678 second(s), 18 queries .
