coat rack hooks
发表于 2021-8-31 23:35:40 | 显示全部楼层 |阅读模式
this is the proto type of the horse shoe cpat racks  for our coat racks. Attached Images
Reply:cpat?  What's a cpat?  (C pat, C pat run?)
Reply:Originally Posted by zipzitcpat?  What's a cpat?  (C pat, C pat run?)
Reply:its coat. sorry for the typeoZach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:I've done similar ones for hanging halters, ropes, etc. on. On mine I weld several shoes together to go on the wall, like UUUUUU. Then, at the edges and welds between the shoes I tilt a whole shoe out to make a hook, weld it on at the front quarter of the shoe, simple and works pretty well. I usually sandblast and use a torch that's starved for oxygen (making some feathers) to carbon it up and then burn the carbon off before putting clear lacquer  finish on it.... gives it sort of a black iron look.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Originally Posted by GreyhorseI've done similar ones for hanging halters, ropes, etc. on. On mine I weld several shoes together to go on the wall, like UUUUUU. Then, at the edges and welds between the shoes I tilt a whole shoe out to make a hook, weld it on at the front quarter of the shoe, simple and works pretty well. I usually sandblast and use a torch that's starved for oxygen (making some feathers) to carbon it up and then burn the carbon off before putting clear lacquer  finish on it.... gives it sort of a black iron look.
GMT+8, 2025-12-26 02:28 , Processed in 0.089484 second(s), 18 queries .
