Can anyone identify this Plasma Cutting Torch?
发表于 2021-8-31 23:35:39 | 显示全部楼层 |阅读模式
This torch came with a used Hypertherm MAX 40 and was not hooked up to the hoses.  I don't think it is the correct torch for this cutter.Thanks in advance,Tom Attached Images
Reply:It looks like a panasonic design for a high frequency cutter.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks!Panasonic?  Oh brother....The consumables look a lot like Hypertherm. (See Pic)   I wonder if this torch might work with the MAX 40? Attached Images
Reply:That is a Hypertherm Powermax 40 torch. It is the first hand held torch from Hypertherm....later units had a molded handle, the early ones were machined from delrin tubing, like the one in the picture. Built in 1985 or so....Jim Colt   Hypertherm
Reply:By the looks of it I would say that your best bet would be to get a replacement that utilizes common consummables.
GMT+8, 2025-12-26 02:27 , Processed in 0.095722 second(s), 18 queries .
