Python push pull gun on older machine, is it possible?
发表于 2021-8-31 23:35:38 | 显示全部楼层 |阅读模式
I have an older lincoln 255 that I want to use for aluminum too.  It needs a control panel to run a spool gun.  I saw a deal on a used 25' python gun and was wondering if there was anyway to run that off my machine?  I know it must have some extra pins on the connector, but does it need anything fancy for power?  It has to control the wire feed, but how does it do speed?  If anyone has any info or maybe a wiring schematic for the python guns.  Thanks.
Reply:Get the Code No. from the data tag on your 255 and give Lincoln a call.I'm sure they could give you the straight dope.Rex
Reply:Hey! go here : http://www.mkprod.com/You should be able to find info on the older units also Thanks!
GMT+8, 2025-12-26 10:15 , Processed in 0.137089 second(s), 18 queries .
