Denrep!!!!!!!!!!
发表于 2021-8-31 23:35:36 | 显示全部楼层 |阅读模式
Fired up the propane rig today.I hope I was able to show the transition from fuel to combined mixture.I have a feeling the clear blue cone/flame is the highest output, and the smaller cone is not as hot.Anxiously awaiting your reply.......  Inquiring minds wanna knowLink to the video (if it works) [ame]http://www.youtube.com/watch?v=Dd2dt_Pqtzk&feature=channel[/ame] And if that doesn't work     Look up Farmersamm, and go to Pic 052.avi BTW............BLEW THROUGH THIS PIECE IN 5 SECONDS   I DO BELIEVE WE HAVE A WINNER HERE Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I'm an O/A guy, so I'm a little bit out on a limb here.  Used to looking at the flame to judge where it ought to be"Any day above ground is a good day"http://www.farmersamm.com/
Reply:The Farmer has discovered video"Any day above ground is a good day"http://www.farmersamm.com/
Reply:WHAAATT!!!???Good dial-in Samm. To make light-up a little easier, after lighting the gas lay the head's side  against a scrap piece, then the collecting flame will allow adjustments to be made quicker, or to more "aggressive" settings, without worrying about a flame-out. You'll usually want to adjust for a neutral to slightly oxidizing flame. The exact adjustment is tough to describe; it's when the inner cone just starts to turn lighter. A little practice and you'll know it when you see it. Once you cross a certain line it doesn't seem like a more oxidizing flame adds more BTUs. The beauty of propane is that with little concern for pressures you can keep alternately adding fuel and O2  to really crank up the BTUs.BTW - I've been trying to get movie smart myself, but it's been a steep learning curve.Good LuckLast edited by denrep; 08-15-2010 at 01:34 AM.
Reply:looked to me like that was rich(carburizing)..
Reply:Thanks If the literature is to be believed, this particular tip is capable of 415,000 BTU's running full out.Fuel pressures range from 7-20psi02 pressures range from 45-65Fuel consumption 80-175CFH02 consumption 150-350CFHThe movie thing is a little weird  It's like entering uncharted territory.  A new concept in backing up what you say with VERY solid proof  I think it could be a great teaching tool.Give your pup a pat on the head for me "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Well samm now you did it..It's a whole new ballgame with propane..Just wait until you try to "Gently" heat some aluminum..Go slow..You will melt alot of stuff and there is very little warning.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:As if all those cigarette butts and welding sparks didn't start enough "shop" fires. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:farmersamm - God forbid comparing rosebud orifice flow capacities and O/A pressures.  -  Opus
Reply:Lotta horsepower there samm, next you'll need another cart so you can manifold the fuel! Have fun!Matt
Reply:No need for a manifold with LP just crank it up and pin the gauge.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-26 10:17 , Processed in 0.124628 second(s), 18 queries .
