sa200 ?
发表于 2021-8-31 23:35:33 | 显示全部楼层 |阅读模式
I was wondering what the difference is between the redface, blackface, and shorthood lincoln 200's. I always see them but I really don't know what the difference in them is?Lincoln 225 RangerSa200            01 dodge  3500 welding rig
Reply:One has a red face, one has a black face and the other has a short hood.[I'm an a**hole!]"These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Tap tap tap...is this thing on?I'm here all week.  Try the veal and remember to tip your waitress..."These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:http://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
Reply:Thanks hardware but besides the obvious lol I didn know what the real difference was.Lincoln 225 RangerSa200            01 dodge  3500 welding rig
Reply:Condensed: Shorthoods are OLD, and copper-wound.  A lot more of the welder portion extends beyond the end of the shielding on the machine, hence the name.  May or may not have electric start.  Redfaces were made through the late '60's, and are also copper-wound.  Blackfaces may be copper-wound or aluminum-wound, and were made after the redfaces.  Sometimes people will switch their aluminum-wound welder's black faceplate with a red one, call it a redface, and try to get someone to fall for it and pay a little more.  So you can't go by the faceplate color if you're looking for copper-wound.  Not to mention the early blackfaces were copper-wound - I have one.What most people want is copper windings (they say they weld better), and any copper-wound SA 200 I've seen has a round generator barrel (not hex-shaped), and the lugs you attach your leads to are on the back face of the machine, not under the hinged side cover.  Note also that the "round" portion of the welder that extends out beyond the back face is NOT the generator - that's the exciter, and that's round on ALL of the machines.  To see the hex you have to raise the side cover and look at the big generator barrel.  Looking at a few pics on ebay should clear it up for you - as soon as you see the hex once, you'll know what to look for.Note that I personally am not making any claims about which one will weld better, I'm just explaining how to tell the difference between models, and how not to get fooled easily into thinking something is what it isn't.Last edited by tbone550; 07-31-2011 at 11:08 PM.
Reply:Originally Posted by shanghyd
Reply:Originally Posted by SteveDjrNow that was funny
Reply:Short hoods have most of the generator exposed...The comment about black faces is not accurate.  I have a 1958 long hood black face.   Short hoods had a black face as well.  The red faces came in somewhere around  1959. The black faces that people talk badly about are the ones with a octagon shaped (flat spotted) generator starting about the 1970.  The generator shape will give it away.  If its round and old then its all copper, but if its octagon, its either aluminum or aluminum clad with copper..or it could possibly be rewound, but still originally aluminum.Last edited by lugweld; 08-01-2011 at 11:17 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldThe comment about black faces is not accurate.
Reply:Thanks Tbone and lugweld for actually explaining it to me it does clear it up. I will be wanting to buy an old 200 soon and was just wanting to know which might be a better choice.Lincoln 225 RangerSa200            01 dodge  3500 welding rig
Reply:Once the crap was sifted out I found that interesting too. Thanks I'm not a red man but interesting..(Meaning Lincoln)Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
GMT+8, 2025-12-26 02:29 , Processed in 0.090009 second(s), 18 queries .
