LIncoln square wave 275 giving me a problem
发表于 2021-8-31 23:35:25 | 显示全部楼层 |阅读模式
I have a square wave 275 that stopped working completely.  It makes a hum but there are no lights in the displays and the fan does not come on.  I verified that it is getting 240 volts to the unit and past the swtich.  I measured some of the voltages from the transformer into the circuit board (suppose to be 18 and 24) and they appear to be 0.  I would appreciate any advice. Thanks
Reply:Call Lincoln, they've always been helpful, even when I've screwed up!http://www.mylincolnelectric.com/LEE...ts/CNMain.aspxRexEdit: Have your Serial# and Code# of the unit when you call.Last edited by rode2rouen; 08-24-2010 at 09:36 AM.
GMT+8, 2025-12-26 02:28 , Processed in 0.095545 second(s), 18 queries .
