Sanitary Welding Ferrel/Fitting Purge Block?
发表于 2021-8-31 23:35:22 | 显示全部楼层 |阅读模式
Need help finding a jig that buisness partner and I used to weld sanitary ferrels to 90s and 45's with. We had a falling out and the fixture was his. I  need one in a bad way and cannot locate. I have attached a computerized sketch of what it looks like. Basically,it's stepped for a 4" ferrel to sit on and will tapper or step up to allow a 1 or 3/4" ferrel to sit on (made from aluminum). Purge gas hose is attached to bottom,  gas passes thru the base and enters the ferrel and fitting on inside. Any help or lead would be appreciated. Attached Images
Reply:I could always make you one..Make a sketch with all the dimentions and presto!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI could always make you one..Make a sketch with all the dimentions and presto!...zap!
GMT+8, 2025-12-26 02:37 , Processed in 0.095023 second(s), 18 queries .
