TB 302 dig settings for 7018
发表于 2021-8-31 23:35:21 | 显示全部楼层 |阅读模式
I have a question for all you Trailblazer 302 owners/ users.What Dig setting do you like best on when burning 7018?I used the lowest setting for a while, but now the second one up seems to give me better strikes/ restrikes.Or is it all in my headusing Escaliber 7018-1 now, but had a mix before.Suppose i could get someone else to set the machine and see if i can tell the difference.But anyhoow! i would like to see the response.G
Reply:I use the softest dig setting for flat welds.  For vertical and overhead I use the second softest setting.This with atom arc and excaliber rods.TB 302 EFIESAB Migmaster 275MM 211 w/Spoolmate 100Hypertherm PlasmaMetal Master, Victor, and Smith TorchesUnihydro 45Wells BandsawArcair K2000Weldcraft Tig rigMiller 12VSLincoln PT 225No one can say I'm brand biased.
Reply:I basically do the exact same as Hank33. I will say my machine hates Excaliburs  in any form. It runs much better with McKay XLM's and Hobart 418's.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:On m bobcat burns 7018s ex on power setting 6 1/8 rod and that is about perfect.
GMT+8, 2025-12-26 02:37 , Processed in 0.097553 second(s), 18 queries .
