Backhoe bucket repair with 120v stick welder?!
发表于 2021-8-31 23:35:12 | 显示全部楼层 |阅读模式
Using my Miller Maxstar 150 STH and 3/32" 7018 @ ~100amps running off a 120v 20amp breaker.Crack running through the wear edge. It took a bobcat and a big gradall forklift to hold it close to where it should have been so I could "tack" it.The crack extends past the wear plate and spiders out into the mild steel bucket. I ground it out with a gas powered 14" demolition saw I found laying around in the guys shop. One million passes later. The plate was like 5/8" or 3/4" thick plus the bucket skin on the back side (3/16"?) on the lower portion.A few passes on the inside as well and you've salvaged one screwy *** tweaked bucket. I love this welder.Welding/Fab Pics: www.UtahWeld.com
Reply:Did you feel that you got proper penetration? Please note I'm not busting your b*lls, just asking out of curiosity.Marc Leonard
Reply:"Miller Maxstar 150 STH and 3/32" 7018 @ ~100amps running off a 120v 20amp breaker."I have to say that Miller welder appears to be the 'Mighty-Mite' of 120 volt welders.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by fronty_78Did you feel that you got proper penetration? Please note I'm not busting your b*lls, just asking out of curiosity.Marc Leonard
Reply:You did it rightI'm sure that using 3/32 was a pain but as log as you gouged it out and welded it back it will workI do this kind of repair work all the timeBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:i love mine! its crazy what it will do! great job on the fixSIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
GMT+8, 2025-12-26 02:37 , Processed in 0.087064 second(s), 18 queries .
