Another CWI Exam question
发表于 2021-8-31 23:35:06 | 显示全部楼层 |阅读模式
Hello all, thanks for your time.One thing that's really on my mind in preparation for the CWI(D1.1) is the Fundamentals section.  I don't want to leave it alone and then find out just how much I don't know about Welding.I've seen that the "Certification Manual for Welding Inspectors" has "everything you need" for this section. Any truth to this?  If it's worth it, I'll try to get one.  Pretty big expenditure....Thanks
Reply:If you go to techstreet.com http://www.techstreet.com/cgi-bin/de...duct_id=232054 you can purchase and download the pdf for $180.  Depending on where you were looking to get it otherwise, that could save you a good chunk of change.  Of course, you would have to print the 314 pages yourself and put them in a binder.  It may also be possible to make friends with your local NDT guys.  They might let you borrow a copy.
Reply:Thanks! I really appreciate it!
GMT+8, 2025-12-26 04:16 , Processed in 0.092769 second(s), 18 queries .
