tacking "ultra coat" fasteners
发表于 2021-8-31 23:35:05 | 显示全部楼层 |阅读模式
I am needing to tack 'Ultra/ armor coated" nuts on the back of a plate and I am wondering how careful I need to be? Basically, are tacking these nuts as bad as welding galv. thats been cleaned with brake cleaner or should I be OK with basic precautions. Thanks for input.
Reply:Not sure what the coating is, but unless they are coated in arsenic or cadmium, I would just avoid breathing the fumes.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Originally Posted by DougAustinTXNot sure what the coating is, but unless they are coated in arsenic or cadmium, I would just avoid breathing the fumes.
GMT+8, 2025-12-26 02:27 , Processed in 0.121209 second(s), 18 queries .
