beam welding
发表于 2021-8-31 23:35:02 | 显示全部楼层 |阅读模式
hii have a question about the different between, to weld a beam in vertical position as shown in this picture or to weld the beam in horizontal position, we have machine also for this positioni am working as industrial engineer, and i am trying to know which one will be better for the company, with the reasonsbest regards,
Reply:Originally Posted by zsie11hii have a question about the different between, to weld a beam in vertical position as shown in this picture or to weld the beam in horizontal position, we have machine also for this positioni am working as industrial engineer, and i am trying to know which one will be better for the company, with the reasonsbest regards,
Reply:lay it flat so u dont have to move it as many times..Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by gimpyrobbWow, an engineer that wants some internet warriors input!? Wonder what kind of grades you got with that AWESOME mastering of the english language. Don't even know how to capitalize the first word in a sentance huh?
Reply:Originally Posted by Doug247lay it flat so u dont have to move it as many times..
Reply:How do you guys keep the I beam from twisting and/or warping?
Reply:Originally Posted by gimpyrobb that AWESOME mastering of the english language. Don't even know how to capitalize the first word in a sentance huh?
Reply:Hi Zsie11 you may want to post your location in your posts so these folks will understand that your not from England (or English speaking country) and that's why you do not speak EnglishIf you want to post your location, show your personal avatar, or have a signature on each post telling fellow members where you are located; an avatar of you or your shop, and a signature telling fellow members what types of equipment you have, you can do it all by following these steps:1. Locate and click on USER CP2. Under YOUR CONTROL PANEL, YOUR PROFILE, click on EDIT YOUR DETAILS3. In the EDIT YOUR DETAILS, you can enter Optional Information and Additional Information such as your Location (an other info)4. While in USER CP you can explore some of the other functions - Avatar: you can have picture of you, your shop, your wife, children, dog, etc (keep it clean- no nudes)- Signature: you can list all your equipment, a link to your shop, or maybe some witty sayingAdd: For those interested  Google has a fast and easy Spell Checker function that is easy to add to your Google Tool Bar. Simply right mouse click on the work Google the click on Google Toolbar Options, then click on TOOLS, then add the check mark next to the Spell Check, this will add the ABC Check icon to your Google Tool Bar. The spell check will also ask you if you meant to use that word and will suggest optional words.Last edited by specter; 07-11-2010 at 11:39 PM.Reason: Add:Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by zsie11and for the movement, we already solve it by good suggestions from shop people, and we fabricated special tools for this
Reply:I think this is an absolutely great place to ask a question.  You will most likely find someone who has already gone through the paces and found an efficient manner to accomplish the task.  If not you will be asking men and women who work with type of problem and would most likely be able to advise which way would be best and may offer insight to possible pitfalls for either option.I can't say as to what the best method would be.  I would pobably have laid it flat and run a sub arc or dual shield in spray using a trolley.  I am would also be concerned about the warp, twist, and flex.  it is possible to weld both opposing fillets on one side at the same time using a trolley and then flip and repeat.  it would minimize your variables on distortion I would think.
Reply:Before i got on with manitoba hydro as a pressure welder i worked at a plant that specifically made structural members for buildings all over the world. The flanges and webs were welded together automatically, whereas connection plates/ clips / lifting lugs / web seams / beveled flange sections / and stiffeners were welded manually by us.When welding the flange to the web we used a huge adjustable dual submerged arc machine. Their was two independant welding heads fully adjustable to the different widths of of various colums we sent through. Some as small as 200 pounds, up to 70,000 pounds. The column laid FLAT with a piece supporting the web and flanges as the column was fed through. I would imagine their would be tolerences for distortion but standing it horizontally such as the pictures youve posted would inhibit the MOST distortion. My recommendation is to lay it flat.
Reply:Did someone cut it twice and it's still to short?
Reply:Originally Posted by 7A749Thread is three years old.Thanks for playin!
Reply:Originally Posted by Hambone2004Wow that was a little uncalled for.
Reply:Originally Posted by 7A749Just three years too late on the response, I'm afraid...
Reply:Looks like a Ogden welder to me , problem is D1.5 limits weld size in flat and horizontal to 5/16 of a inch and 1000 amps.Works for most usa bridge girders .Seen Highs, Haberlies, National Eastern,& Tampa Steel Erectors girder makers and am not impressed. We jig them flat in a home made jig , tack and postion weld at 45 degrees .We then weld with LA-75/860 flux.  900 amps 5/64 Tiny Twin LT-56/LT-7 tractors most position at 45 degrees works for us 103 years in busness Harris Structural Steel Co.
Reply:Originally Posted by PavinsteelmanLooks like a Ogden welder to me , problem is D1.5 limits weld size in flat and horizontal to 5/16 of a inch and 1000 amps.Works for most usa bridge girders .Seen Highs, Haberlies, National Eastern,& Tampa Steel Erectors girder makers and am not impressed. We jig them flat in a home made jig , tack and postion weld at 45 degrees .We then weld with LA-75/860 flux.  900 amps 5/64 Tiny Twin LT-56/LT-7 tractors most position at 45 degrees works for us 103 years in busness Harris Structural Steel Co.
Reply:Slow we are welding over 35 lbs an hr with the tractor !!!
Reply:We position the girder at 45 degrees run the head vertical , and pour it in . EMT what is the PQR for that weld you have ??? See the spatter is this metal cored wire . In the USA all states require sub arc for all web to flange welds to be done full auto only . Many use Lincoln Squirtmobiles to conform to this running 5/64 or 3/32 wire . Watched a girder fitter at work ,took 6 men to run it and welded with a single 3/16 L-61 wire on both sides web vertical, .not very productive in my mind.
GMT+8, 2025-12-26 02:37 , Processed in 0.070054 second(s), 18 queries .
