I built a jungle gym.
发表于 2021-8-31 23:34:59 | 显示全部楼层 |阅读模式
For my parrot I just got Used 1/8 308 (i think) stainless rod and stainless safety wire as filler. miller syncrowave 250, foot pedal, 1/16 2% tung. 60ish amps.The bird is a 6 month old sun conure named Sunny.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:That's pretty cool I like it!!
Reply:Sucked me in!  That is clever and obviously Sunny likes it.  Nice job.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Over-engineered I see Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Originally Posted by NiteskyOver-engineered I see
Reply:I expected to see monkey bars made of 2 or 3 inch curved pipe - like at a kids' playground.Fooled Me!  This... well, it's for the birds! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:make sure the openings are big enough he cant get stuck and break his neck..ive found that tig is the best way to make the  100 tiny welds in these projects...Last edited by weldbead; 08-13-2011 at 10:56 AM.
GMT+8, 2025-12-26 04:18 , Processed in 0.094964 second(s), 18 queries .
