Rolling Tig Stand
发表于 2021-8-31 23:34:57 | 显示全部楼层 |阅读模式
Here is a shot of my first aluminum project using the new welder . Nothing fancy for sure but it gets the machine up off the floor and is easy to move . It was a fun project to get used to tigging aluminum Welded using 1/8" wall 6061  1"square tubing .3/32 Ceriated tungsten3/32 4043 filler200hz freq.70% EN Attached ImagesMiller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
Reply:Mine rolls also.Was a fun project.Also added cooler at the same time.My2¢V. Attached Images
Reply:I like the large wheels!Longevity 200 DX Ac/Dc Pulse tigMiller 250 DX tig runnerLongevity Migweld 250p Panasonic 261 Gunslinger MigTorchMate CNC tableLongevity Force Cut 60iJet 14 x40 lathe with DROJet Mill with DROGarage Customs TRCA51 channel on youtube!
Reply:Originally Posted by Tigster200Here is a shot of my first aluminum project using the new welder . Nothing fancy for sure but it gets the machine up off the floor and is easy to move . It was a fun project to get used to tigging aluminum Welded using 1/8" wall 6061  1"square tubing .3/32 Ceriated tungsten3/32 4043 filler200hz freq.70% EN
Reply:Thanks fellas Miller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
Reply:Originally Posted by VinnieMine rolls also.Was a fun project.Also added cooler at the same time.My2¢V.
Reply:Tigster,   Your cart looks really nice! Be careful when drag thru the shop not to let it tip over sideways. Your casters won't mix well with small rocks or chunks of slag against the concrete.  Nice to see a cart that is made out of Al.Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Very nice man, I like the design. Its a lot more creative than what you usually see [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Thanks Lanse Miller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
Reply:Jackalope , you are certainly correct about small wheels not playing well with obsticles on the floor . Fortunately ( or unfortunately ) , my shop is very small and the Tig welder does not have to go far . The stand was really intended to put the face of the machine at the proper height so when I am welding at my table, I can make machine adjustments ( if needed ) simply and quickly by just turning around .I also wanted something that looked a bit different than the usual  Miller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
Reply:Originally Posted by jackalopeIs there a reason you have an O2 tank strapped on there. I know my Dynasty performs slightly better with Argon
Reply:Originally Posted by Vinnie02 ?????That is an  "m16" air liquide argon!!!!  "LOL"Not all 02 are green.V.
Reply:Hey that's my welder!I just make an aluminum cart too lolYou need to throw that torch away and make a water cooled setup like I did!http://weldingweb.com/vbb/showthread.php?t=58517Welding/Fab Pics: www.UtahWeld.com
Reply:I just got the Powertig 200DX a couple of weeks ago . How is yours performing ?Miller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
Reply:Both carts are very nice but i do like the big tires on vinnie's cart because i do some outside of the shop work and would have to roll the cart in less than ideal conditionsBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by Tigster200I just got the Powertig 200DX a couple of weeks ago . How is yours performing ?
Reply:I hear ya  I used to have a Miller Syncrowave 200 and I like the Everlast 200DX a LOT more ! Especially on aluminum .  I am only a hobby welder so hopefully the machine will be reliable .Miller MM252 with Q300Hypertherm PM1000Everlast Powertig 200DXMiller Syncrowave 200
GMT+8, 2025-12-26 02:51 , Processed in 0.072396 second(s), 18 queries .
