Mobile Welding/ Fab Shop...
发表于 2021-8-31 23:34:56 | 显示全部楼层 |阅读模式
Here is the old dragster trailer converted into a mobile weld shop..Nothing special but very functionable..Chop saw..Lincoln Toumbstone..Portable bandsaw..Oxy Accet, set up..Toolboxes..220 ready plug from the Trailblazer..And here is how you get the trailblazer out of the back of the truck..He has a garage being built now that will be equipped with a hoist for the welder..But for now 2 trees some cable and a chain hoist does the trick....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Why do you need the tombstone if you have trailblazer??
Reply:Originally Posted by DemonSpeederWhy do you need the tombstone if you have trailblazer??
Reply:That makes sense.... What type of work will you be doing it the little fab shop?
Reply:Most anything that fits inside..It's way better than doing stuff outside in the blazing sun or rainstorms......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterIt's way better than doing stuff outside in the blazing sun or rainstorms......zap!
Reply:Awesome!www.thefusionsolution.com
Reply:Glad I'm not anywhere that its that hot but I would trade the constant high humidity of %75 - %95 I deal with every day.  You sweat so bad that after a while you end up with heavy heat rash over large area's of your body or more concentrated area's that end up bleeding.  I have a bullard air vest but it seems to have been made for someone thats 4 foot tall with a 50 inch waist so I'm going to make my own vest that fits better and pushes air up the back side of the shield / hard hat and down towards the groin and into the armpits.Welding Supervisor Department of Corrections.
Reply:Originally Posted by zapsterMost anything that fits inside..It's way better than doing stuff outside in the blazing sun or rainstorms......zap!
Reply:One of those portable picnic table canopies would help with blocking the sun, you can get them from wally world for around $60 or so and their around 10'x 10' or so.  The portable carports  go up to 16' x 20' and sell for around $200 or so but you can set them up and break them down in a few minutes.Welding Supervisor Department of Corrections.
Reply:Nice looking set up, if you are not going to weld or cut steel in it. Looks like a fire waiting for a match.Be safe.Tim Beeker.
Reply:Originally Posted by tnjindNice looking set up, if you are not going to weld or cut steel in it. Looks like a fire waiting for a match.Be safe.
Reply:Carefull with that closeline setup your way over the WLL of that wire even with that little tombstone hanging off of it.   Looks like regular 3/8" wire rope.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieCarefull with that closeline setup your way over the WLL of that wire even with that little tombstone hanging off of it.   Looks like regular 3/8" wire rope.
Reply:I'm trying to figure out that last picture... you hoisted the TB out of a truck, and then with it still hanging there, you paused for... a wedding reception?__David Hillman
Reply:Originally Posted by David HillmanI'm trying to figure out that last picture... you hoisted the TB out of a truck, and then with it still hanging there, you paused for... a wedding reception?
Reply:Originally Posted by joedirt1966OH MAN!......Many of us can relate. 35 days consecutive days (and counting) of 100++ degrees!  The garage is still 100 degrees at 6am.  Up to 108-110 degrees by 5pm.Sheeesh!  Hope you are keeping cool with your new digs.
Reply:Originally Posted by zapsterPig roast last Saturday..That machine has been hanging there since mid July.....zap!
Reply:Zap, keep your eyes open for a roll out awning from a camper , great on the side of those trailers just for the reasons you stated. double your under cover area real quick."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I think the best feature of the trailer is the poster on the wall in the 2nd picture!
Reply:Originally Posted by AndyAI've been building a barn on the weekends.  Start at 6am, have to quit around 11am.  Then find a hole to hide in for a few hours.Seems like the heat isn't so bad after about 5pm.  Yeah, the temperature is probably still high, but the sun isn't beating down on you as much.I drink maybe 2 gallons of water a day.  At the end of the day my shirt has white streaks from the salt.  Seems like it's really bad this year.
Reply:Those have pretty decent floor space. I am working on one of them right now. I have the whole drivers side stripped of the aluminum outer skin. No fasteners at all, only 3M tape. It is about as easy as skinning the hide off of a whale though. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by jwolfI think the best feature of the trailer is the poster on the wall in the 2nd picture!
Reply:Originally Posted by zapsterThat's not the toumbstone..That's the Trailblazer!...zap!Are them trees  and cable    osha   approved  ..   lol         ...            looks like it should  hold   ......................................  welll  ............................. maybe                      haha>Innovations are what i leave behind for History
GMT+8, 2025-12-26 02:27 , Processed in 0.166530 second(s), 18 queries .
