Simple Aluminum Box
发表于 2021-8-31 23:34:54 | 显示全部楼层 |阅读模式
I built a simple aluminum box for a customer. It is going on something cool . I will post pics of it installed in the future.16 gauge.www.performancealuminumfabrication.com
Reply:Nice, clean, and simple. That usually sticks out than a bunch of fancy crap.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Nice job!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:beautiful is all i have to sayLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Vary sweet work. Everybody should take note of the design of the corner in pic 3 it gets no stronger than that and that same design can be adapted to angle.
Reply:Battery box??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by Fat BastardVary sweet work. Everybody should take note of the design of the corner in pic 3 it gets no stronger than that and that same design can be adapted to angle.
Reply:Nice job, man!! I like it. Looks dang square to me [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Now you're just showing off!Lincoln Pro Mig 180Everlast PowerARC 200
Reply:It is going to be a battery box on the worlds biggest jet ski? I want a ride.....
Reply:Nice work! nice welds!www.thefusionsolution.com
Reply:Oh I like this :]
Reply:BEAUTIFUL!Now since I'm not very good with making 'square things', exactly how to you cut out the 5 panels for the box?  For example, are two of the opposite panels 1/8" or so 'wider so that the 'other set' of side panels fit inside?  Meaning, do you add the thickness of the metal to two (2) of the panel length measurements so that they 'Fit well' (small panels inside the longer ones) before you tack em' in place?  I always sorta' wondered about that.  I would like to make some 'very small' boxes out of Copper and some from Aluminium and would like to know.Cheers,/Joe..Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Originally Posted by ironwelderVery tidy job, how long have you been welding?
Reply:Originally Posted by travisc454It may sound crazy but I have only have 24 hours on my dynasty. Its the only welder i have ever owned. I took a part time job for 10 bucks an hour and probably got another 10 hours. Thats arc time. Not a lot. But welding is the easy part. I could literally teach someone with above average coordination to weld just like this in a few hours(I've done it) Give me a month and they could possibly, and probably would be better than me. Its the designing, forming, cutting, measuring, controlling heat distortion, etc. thats hard. Thats just my opinion. Sometimes I try to explain how I do things, but because its different, it rocks the boat around here.
GMT+8, 2025-12-26 02:27 , Processed in 0.095301 second(s), 18 queries .
