mig welder shopping
发表于 2021-8-31 23:34:50 | 显示全部楼层 |阅读模式
ok for starter i have a blue point m135 amp mig weld great does most projects i come up with but...i reciently enrolled into a night welding class and have been using there millermatic 211.251,350  also a old esab 250 that being said now i feel like my welder is not worthy to do any real work...my opinion.... im looking for a nice 220 mig and i am open to all suggestions miller lincoln.ta,,,,i will be doing mostly all automotive frame work roll cage work nothing thicker than 3/8 let here your thought weldingweblincoln square wave tig 175blue point mb140 mig
Reply:Out of that list I'd go with the MM211 in the bang for the buck dept.  It's a nice machine and reasonably priced.  It's plenty enough to do the majority (if not all) of race fab you'd need with MIG.  For most road, circle track and drag cars the 211 will be plenty big enough and big enough for all but the beefiest off road.  I find that the thicker material I use is for trailers and pit equipment and what's too big for the MIG I use stick.Enough stuff to build and repair wrinkled up race cars or bring a classic back to life...
Reply:@ Cautowerks - Rip the MM211 for $1080 (http://www.weldersupply.com/productd...&ID=36&pID=275).  Misses your 220A requirement by 9 meager Amps.  If you really need to frequently weld at 220Amps, you would be best served with a 250Amp rig.  Seems that for auto body werk, a 211 is a perfect fit. Go Blue!Last edited by ManoKai; 03-16-2013 at 11:54 PM."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:the mm211 i use in claas is much larger then that one it is wheel mounted and looks just like the mm 250 is this a older model at my class?lincoln square wave tig 175blue point mb140 mig
Reply:You are probably using the MM212, not the MM211. The 211 is a small unit that is dual voltage. The MM212 is a larger cabinet machine similar in size to the MM250-252 units.Output on the MM211 is fairly close to that of the 212, but the duty cycle is way less. The 211 is also much less expensive. If you are looking for an older machine to save some money, the MM200, MM185, MM250 DVI were all larger cabinet type machines with decent duty cycles. Output would vary depending on the machine, but any of those would do 3/8" or less with no issues. The MM185 would be the least powerful of the lot followed by the DVI. The MM200 would be the oldest of the bunch, but is still one of the nicest migs ever made..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWYou are probably using the MM212, not the MM211. The 211 is a small unit that is dual voltage. The MM212 is a larger cabinet machine similar in size to the MM250-252 units.Output on the MM211 is fairly close to that of the 212, but the duty cycle is way less. The 211 is also much less expensive. If you are looking for an older machine to save some money, the MM200, MM185, MM250 DVI were all larger cabinet type machines with decent duty cycles. Output would vary depending on the machine, but any of those would do 3/8" or less with no issues. The MM185 would be the least powerful of the lot followed by the DVI. The MM200 would be the oldest of the bunch, but is still one of the nicest migs ever made.
Reply:I used a mm250 (I think?) thing was a beast of a machine.If you want new, Lanse just did a video on the HTP 2400. Or how about a hobart. I haven't read a single complaint about a hobart (or htp for that matter mig welder)http://store.cyberweld.com/hobmigwel.htmlTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:With the MILLER rebate the 211 seems the best buy for the buck.
Reply:Originally Posted by ManoKai@ Cautowerks - Rip the MM211 for $1080 (http://www.weldersupply.com/productd...&ID=36&pID=275).  Misses your 220A requirement by 9 meager Amps.  If you really need to frequently weld at 220Amps, you would be best served with a 250Amp rig.  Seems that for auto body werk, a 211 is a perfect fit. Go Blue!
Reply:i beleive the machine might have been a mm210 at my night class very happy using that machine i could deffintlty see making good use of that class size machine. i found one on ebay dor $1100in like new condition with a mm100 spool gun. i also looked at the hobart ironman 230 seem to be pretty nicelincoln square wave tig 175blue point mb140 mig
Reply:Dan here really likes his Hobart Ironman 230. It's probably one of the better deals out there for a cabinet sized machine new on a budget..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by Cautowerksi beleive the machine might have been a mm210 at my night class very happy using that machine i could deffintlty see making good use of that class size machine. i found one on ebay dor $1100in like new condition with a mm100 spool gun. i also looked at the hobart ironman 230 seem to be pretty nice
Reply:Looked on craigslist for fun and fount a  linde vi-206 and wire feeder for 300 bucks  and a ironman 210 for 700 also a mm210 for 850 but its 2 hours awaylincoln square wave tig 175blue point mb140 mig
Reply:Originally Posted by DSWDan here really likes his Hobart Ironman 230. It's probably one of the better deals out there for a cabinet sized machine new on a budget.
Reply:Originally Posted by DSW  The MM185 would be the least powerful of the lot followed by the DVI.
Reply:what's your budget? For a budget option, I really like my Hobart Handler 190. Got it on sale at tractor supply for $649Miller Multimatic 255
Reply:Originally Posted by dstevensOut of that list I'd go with the MM211 in the bang for the buck dept.  It's a nice machine and reasonably priced.  It's plenty enough to do the majority (if not all) of race fab you'd need with MIG.  For most road, circle track and drag cars the 211 will be plenty big enough and big enough for all but the beefiest off road.  I find that the thicker material I use is for trailers and pit equipment and what's too big for the MIG I use stick.
Reply:i went to local welding shop today and the sellsman almost has me sold on a lincoln powermig 216 combo with lincoln viking helmet and set off gloves and jacket for $1575 out the door what do you guys think about that machine and the deal i went in to look at the millermatic 212 almost 600 more then this deal on lincolnlincoln square wave tig 175blue point mb140 mig
Reply:Originally Posted by Broccoli1I think he means 220v
Reply:Originally Posted by Cautowerksi went to local welding shop today and the sellsman almost has me sold on a lincoln powermig 216 combo with lincoln viking helmet and set off gloves and jacket for $1575 out the door what do you guys think about that machine and the deal i went in to look at the millermatic 212 almost 600 more then this deal on lincoln
Reply:Lincoln has a rebate program in progress. Here's info. http://www.lincolnelectric.com/en-us...t_moneymatters
Reply:I just bought the Ironman 230. Welding Tips and Tricks has a nice review on it?
Reply:Im thinking about the Lincoln 256 machine, cant swing the spool gun, but  I think this would be a great machine. For what its worth Kyled123, my cousin has an older Ironman, its had a very rough life, he has a contracting company and is always welding something. The machine has performed awesome! He bought the spool gun for it when he bought some  alum body dump trucks, that worked well also. The machine is still going strong.....
Reply:If your looking at a used machine, dont be afraid to look into an older Esab 250 mig. Them older Esabs were excellent machines performance and durability wise.If I was looking at a new mig machine, I'd seriously consider one of the newer Thermal Arc 3 in 1 units.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:im stummped now between new or used..i went out of town this weekend and while out i looked at a millermatic pulsar" guy didnt kno anything about it and it was near new condition with a 250cf tanks for $1,000 bucks but all reviews i fount on this pulsar machine had me confused on what it actually was.lincoln square wave tig 175blue point mb140 migAnyone know anything about the millermatic pulsar 200 amp shop mig welder any advice would be nice thinking about buying this weekendlincoln square wave tig 175blue point mb140 mig
Reply:Look up the manualSyncrowave 300Maxtron 450, S-52E, 30A
Reply:I'm not a big Miller fan, but I really like the 251/252.  I have used a 212, and was not happy with it. but I'm also biasedWhen it comes to buying used, you have to be careful. I have seen distributors take hard used systems and put new cases on them.138# anvilHomebuilt 6 tap kegerator100# cone anvil5" post viceVarious hammers ranging from 250g to 2000gSome tongsA few screwdriversA wrench or twoOh, and a Fronius TPS 2700
GMT+8, 2025-12-26 06:21 , Processed in 0.165628 second(s), 18 queries .
