Running .035 through .045 liner?
发表于 2021-8-31 23:34:49 | 显示全部楼层 |阅读模式
I just ordered 30lbs of .035 to replace the .045 solid wire I've been running in a Lincoln Power MIG 255.  I recently replaced the liner in the gun, which is set up for .040-.045 wire Lincoln Tweco 42-4045-15).  Here's my question, will I be able to reliably run .035 wire through this liner, or will I need to replace with a .030-.035 liner?
Reply:I run .030” wire through an .045” liner all the time with no problems.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Its what we do at work, I dont feel like ordering two sizes of liners and having to change liners when we change wire. I get the same liners 4045-15.
Reply:On my old Mig machine that I sold, but still have the same Tweco Mig gun, I ran .023” wire through the .045” liner with no problems. With this new wire feeder I don't have .023” drive rolls.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:You will have no issues running .035 wire in a .045 liner. You most likely will have issues running .023 wire though a gun depending on length / Luck etc.. The main thing about running the correct drive rolls./output guides. gun liner will be the area of arc quality. Just gets a bit better when everything is matched correctly. Sometimes way better, depending on the setup..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:I have a 1/16" liner in both my guns and run .035 to .052 with no problems.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I've seen issues with really long guns(over 15') and mis-matched wire - liner sizes.  Or guns with 90° goose necks that create a lot of drag on the wire.  But generally have no isues with over sized liners.  If you have trouble with the arc length not being stable, or with the stickout pulsing, that's a symptom that could be related to the large liner- small wire setup.  Small diameter wire can bunch up inside the liner and then straighten out.  If it happens, try straightening out the gun cable and check to see if the problem dissappears.  As a last resort, switch to a gun liner that's an exact fit for the wire you're using.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:I run 1/16" liner almost exclusively. I just take the contact tip off when I feed wire to avoid hangups there.  If you run dirty wire, the extra size will prevent you from changing your liner as often.138# anvilHomebuilt 6 tap kegerator100# cone anvil5" post viceVarious hammers ranging from 250g to 2000gSome tongsA few screwdriversA wrench or twoOh, and a Fronius TPS 2700
GMT+8, 2025-12-26 10:17 , Processed in 0.098154 second(s), 18 queries .
