Burnishing wheel compounds?
发表于 2021-8-31 23:34:49 | 显示全部楼层 |阅读模式
Hi guys. What are you guys putting on these wheels to finish SS or aluminum?
Reply:Originally Posted by aDreamSoRealHi guys. What are you guys putting on these wheels to finish SS or aluminum?
Reply:I'll second Caswell Plating. I use stitched wheels, and green rouge when I want a mirror on something. They claim it won't change critical dimensions, that's false, you can absolutely put waves, break corners, etc with it. But it still doesn't cut as fast as some things. If I'm trying to cut deeper scratches out I used their greaseless compounds. They cut quite fast. Getting a wheel loaded with them is a bit of a pain, but once you've got one loaded up it can be reloaded pretty easily.
Reply:Guys. I'm not sure that stuff will work with this type of wheel?
Reply:I get my stuff from this guy. He's happy to talk to you on the phone and seems very knowledgeable. http://www.lehighvalleyabrasives.com/servlet/StoreFront
GMT+8, 2025-12-26 04:36 , Processed in 0.139026 second(s), 18 queries .
