OT: What is this thing I found in the ditch?
发表于 2021-8-31 23:34:49 | 显示全部楼层 |阅读模式
Is it for drug use? Been finding some of that stuff latelyhttp://s1357.photobucket.com/albums/...er_media_shareLast edited by woof; 03-30-2013 at 12:33 AM.Reason: Image didn't showA man who can't weld is as poorly educated as a woman who can't sew
Reply:I don't know what you found in the ditch but I found this in a ditch and took it home with me. Attached Images
Reply:I would have left it, there are much better malt liquors than Colt 45!!
Reply:Never found either of those in the ditch....used to find women like that in a bar some years back - given that up thankfully However, that clear thing looks like a tubing connector for medical use or something.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:It is a mouthpiece for a PBT (portable breath test). Probably a DUI stop there at some point and the officer had the suspect give a breath sample.
Reply:That would also explain what Inkydoggy found as well....No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by AKmudIt is a mouthpiece for a PBT (portable breath test). Probably a DUI stop there at some point and the officer had the suspect give a breath sample.
Reply:I would return it to the police station and say I found this litter in the ditch.
Reply:Yeah VPT, good way to get the Police to note you down as a potential 'trouble-maker'.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:what were you doing in the ditch?
Reply:"I found this in the ......  uh ditch, yeah, that's it, the ditch".
Reply:Originally Posted by TimmyTIGwhat were you doing in the ditch?
Reply:It's a dual pencil sharpener! You stick two pencils in there then spin em like a woodworkers c clamp  Good score INKY! I would have kept that one too, they're like welding machines, you could always find room for one more, even if they look good on the outside but still dont operate correctly, it'll eventually serve a purpose I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeeven if they look good on the outside but still dont operate correctly
Reply:Originally Posted by SuperArcYes, those are mouth  pieces for a "PAS" device.  "Portable Alcohol Screening" device.  I used them all the time. .  (Remember, I have dual careers   )
Reply:Originally Posted by InkydoggyDamn I did not know you were a Drunk and a Welder too!
GMT+8, 2025-12-26 06:19 , Processed in 0.132887 second(s), 18 queries .
